Your basket is empty
Caretech Telecare Heat Detector
Quicklinx: 95LXWS00 Mfr#: 300140
£61.54 ex VAT
£73.84 inc VAT
The Heat detector will trigger a call from the carephone and provide a local audible alarm when the temperature rises to 58oC. A heat detector is suitable for those locations where a false alarm is likely to occur with a standard ionization and optical smoke detector due to steam, cooking flame or particles (e.g. burning toast).Tested to comply with all relevant standards.
