Your basket is empty
Caretech Telecare Elliot Radio Alarm Trigger
Quicklinx: 92CNWS00 Mfr#: 300005
£38.60 ex VAT
£46.32 inc VAT
Pro5 Consortium Telecare Homepage
< Click here to return to Pro5 homepage
  • **Auto test function** - The alarm trigger can be programmed to automatically send information to the carephone related to battery life and range to ensure that the user is always able to make a call.
  • **Waterproof** - The alarm trigger is waterproof to the IP67 standard.
  • **Status LED** - Visual call indication and confirmation of battery life and other programmed functions.
  • **Life time low cost savings** - the alarm trigger can have the battery changed by non-technical member of staff. The battery type is CR2430 Lithium 3V and once changed the pendant is waterproof as it contains a specially designed seal. This provides big savings when compared with a typical pendant exchange.
  • **`Easy Click' Accessories** - Neck cord, wrist strap, belt clip and the unique Easy Press Button for people with limited dexterity.
  • **Dual Button** - Five different actions can be programmed.
  • **Dual frequency transceiver** - Transceiver transmits on a dual frequency of 868/869 MHz European social alarm frequency providing the ultimate protection against interference from other radio devices.
Please note this device is compatible with CareTech systems only.
