Your basket is empty
Caretech Telecare Chair Sensor Complete
Quicklinx: 95LPWS00 Mfr#: 300022
£149.98 ex VAT
£179.97 inc VAT
Sense Chair sensor consists of sensor (chair mat) which connects to the sense MBox radio device. The sense mat is placed under the cushion on a seat or wheelchair. When the sensor activates an alarm is sent to carephone. The sense alarm provides automatic monitoring of battery and sensor function. On the main unit a simple function provides the ability to set different delay times before the alarm is sent for example if the client was to exit the bed and not return in 15 minutes. Time parameters can also be programmed so that the device will only work within certain times of the day for example between 9.00pm and 6.00am
