Canon WU10 Wi-Fi Unit for High Speed Document Scanners
Quicklinx: 9KWWWS00 Mfr#: 6910B003
  • IEEE 802.11n
The portable WU10 enables wireless scanning to mobile devices, delivering a truly mobile scanning experience without the need to connect via cable to a network point or external power.
  • Ideal portable scan-server
    The WU10 optional Wi-Fi unit is the perfect addition to our range of imageFORMULA mobile scanners. It empowers users to scan wirelessly when on the move or in the office, so they can work productively without needing to connect to a power source or network.
  • Fast scanning wherever you are
    With Wi-Fi it is possible to scan wherever you are – in the office, at home, on the road or at customer service points. Speed up the process of data validation and decision making by scanning important information, such as contracts, identity authentication documents and household bills, to your mobile, tablet or PC device and send to either a predefined business workflow or to a cloud-based application. The WU10 makes it possible to scan up to 400 images (200 dpi) when the battery is fully charged, so you can enjoy fast, mobile scanning without compromising performance.
  • CaptureOnTouch Mobile
    You have the flexibility to scan direct to your iPhone, iPad and Android device wherever you are, using our powerful scanning software, CaptureOnTouch Mobile. Save valuable time with features that include double-sided scanning of documents in a single pass. Advanced image processing tools, such as auto document size detection, deskew and blank page deletion, give consistently superior image quality results. This free app is available for both iOS and Android devices. For greater productivity on the move you can run batch scans and save the information you've gathered to the cloud or add to business workflows. For more information please view related software.
  • Easy to connect and use
    The Wi-Fi unit WU10 is easy to use – simply connect it via USB to your mobile scanning device to provide power and enjoy the freedom to work wirelessly. With an intuitive, colour-coded information panel it is simple to operate so anyone can use it.
  • Versatile Wi-Fi connectivity
    The optional Wi-Fi unit can operate in both access point and station mode (peer-to-peer) environments. Mobile executives who are always on the move, can connect their WU10 to their Canon mobile scanner to activate a wireless link direct to their mobile or tablet device. In the office, the scanner can be shared amongst a group of users via a company's Wi-Fi network server or by direct Wi-Fi connection.
Canon WU10 - network adapter - USB 2.0 - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
USB 2.0
7.5 cm x 5.06 cm x 2.98 cm
125 g
Belgium, Bulgaria, Czech Republic, Estonia, Lithuania, Iceland, Romania, Luxembourg, Hungary, Cyprus, Liechtenstein, Malta, Slovakia, Slovenia, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, Greece, Turkey, Ireland
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Apple MacOS, Microsoft Windows
DR-P215; imageFORMULA P-150, P-150M, P-215, P-215 Scan-tini
Network adapter
External
USB 2.0
Ports
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Access Point operational mode, WPS
1 x USB 2.0 - 4 pin USB Type A
1 x USB
Li-ion battery
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Power adapter - external
12 Watt
Software Included
Drivers & Utilities
7.5 cm
5.06 cm
2.98 cm
125 g
10 °C
32.5 °C
20 - 80%
Canon DR-P215 , Canon imageFORMULA P-150, P-150M, P-215, P-215 Scan-tini
