Canon Speedlite 430EX III - RT Flashgun Black
Quicklinx: CX3GWS00 Mfr#: 0585C011AA
For stunning flash photography even in complex lighting environments, Canon's Speedlite 430EX III-RT offers a fantastic combination of advanced features and simple operation. Compact in size, yet powerful in range, the Speedlite 430EX III-RT not only provides a portable light source, it has easy to manage features that can enhance contrast, color temperature, brightness and focus of light for more natural-looking photography. Whether bouncing the light source off a wall or ceiling, using its integrated Catchlight panel to brighten up a subject's face, or using its bounce adapter to soften the intensity of the flash beam, the Speedlite 430EX III-RT is impressively versatile. With convenient custom and personal functions, speedy recycle times and advanced wireless photography options, the Speedlite 430EX III-RT can be an indispensable accessory for photographers ready to take their flash photography to the next level.
  • Powerful, yet compact enough to take anywhere
    The Speedlite is lightweight and compact, so there'll always be room for it in your bag. Powered by readily-available AA batteries, the flash recycles following a full-power flash in seconds.
  • Simple controls and an intuitive interface
    The controls on the Speedlite 430EX III-RT echo those of many EOS cameras. Shortcut controls give access to key features, and a control wheel allows quick adjustments to be made. A lock switch prevents settings from being changed accidentally. An LCD screen shows settings and shooting information at a glance, and is illuminated for low-light conditions.
  • Use remote flash to create the look you want
    Speedlite 430EX III-RT flashes can also be placed away from the camera, to simulate light coming from different directions. Using radio frequency triggering, Speedlite 430EX III-RT units can be controlled from meters away, and do not require direct line of sight with the camera. This means they can be situated in more places, letting you create even more moods and effects. The Speedlite 430EX III-RT can also be remotely controlled with optical triggering, so it will fit in immediately with your existing flash set up. Use multiple flashes together in groups, controlling the power of each group separately.
  • Shoot flattering portraits using bounced light
    A movable flash head allows light to be bounced from large surfaces, like walls or ceilings, creating soft, shadow-free lighting that's perfect for portraiture. A built-in reflector panel can be deployed to create sparkling catch lights in a subject's eyes, bringing their expression to life. The Speedlite 430EX III-RT can also zoom its flash output to match the angle of view of the lens being used.
  • Dual wireless flash triggering
    The Speedlite 430EX III-RT can be fired while off-camera using radio-frequency or optical triggering, giving photographers huge versatility. When using radio-frequency triggering, flashes can be placed away from the camera and do not have to be within direct line of site. This means they can be placed in many more locations, such as outside a room firing in through a window.
Canon Speedlite 430EX III-RT - hot-shoe clip-on flash
Camera Flash
Hot-shoe clip-on flash
7.05 cm x 9.82 cm x 11.38 cm
295 g
Guide Number (m / ISO 100)
43
Lens Coverage
24mm - 105mm
Supported Exposure Control
TTL, E-TTL, E-TTL II
Zoom
Automatic, manual
AF illuminator, illuminated LCD display, flash +/- compensation, wireless off-camera control, modelling flash capability, slave function, high-speed synchronization (HSS), rear curtain synchronization, built-in radio transceiver
Required Battery
4 x battery - AA type
EOS 1300D, 1500D, 1D, 2000D, 200D, 250D, 3000D, 4000D, 5D, 77D, 800D, 80D, 850D, 9000D, 90D, Kiss X10, Kiss X10i, Kiss X80, Kiss X9, Kiss X90, Kiss X9i, M6, R5, R6, Ra, Rebel SL2, Rebel SL3, Rebel T100, Rebel T6, Rebel T7, Rebel T7+, Rebel T7i, Rebel T8i, RP; PowerShot G1
7.05 cm
9.82 cm
11.38 cm
295 g
Camera Flash
43
Lens Coverage
24mm - 105mm
Shooting Distance
0.7 m - 23.6 m
Vertical Rotation Angle
+90 / 0
Horizontal Rotation Angle
+150 / -180
Zoom
Automatic, manual
Manual Power Control Levels
1/128
Power Consumption
Recycling time - 0.1 - 3.5 sec / 1200 flash: - with 4 x AA type - Alkaline
Required Battery
Canon EOS 1300D, 1500D, 1D X Mark III, 2000D, 200D, 250D, 3000D, 4000D, 5D Mark IV, 77D, 800D, 80D, 850D, 9000D, 90D, Kiss X10, Kiss X10i, Kiss X80, Kiss X9, Kiss X90, Kiss X9i, M6 Mark II, R5, R6, Ra, Rebel SL2, Rebel SL3, Rebel T100, Rebel T6, Rebel T7, Rebel T7+, Rebel T7i, Rebel T8i, RP , Canon PowerShot G1 X Mark III
