Product
Canon SELPHY CP1200 Compact WiFi Photo Printer - Black
Quicklinx: CDLJWS00 Mfr#: 0599C011
The SELPHY CP1200 wireless compact photo printer is so much fun to use, you'll want to take it everywhere with you - and you can! Thanks to its compact design and multiple ways to print wirelessly, you can print just about anywhere. But there is more to it than that. It's actually fun to print with the SELPHY CP1200. You can print on postcard-size paper, label size and even several little stickers at a time. And before you print you can dress up your photos with fun borders and effects. Do you ever need a picture for an ID or passport? Don't go to the convenience store, just print your favorite picture of yourself. The SELPHY CP1200 has many built-in ID sizes so you can print just the right size for your needs. On top of all this, you can print to the SELPHY CP1200 however you want - wirelessly from your computer, via USB, from a camera or a memory card... the list goes on. With it, it's so convenient, fun and easy to print your favorite photos whenever you want to!
Canon SELPHY CP1200 - printer - colour - dye sublimation
Printer Type
Compact photo printer - dye sublimation - colour
Portable
860 g
Max Media Size
148 x 100 mm
Min Media Size (Custom)
100 mm x 148 mm
Max Media Size (Custom)
100 mm x 148 mm
Print Speed
Up to 0.78 min/page - 148 x 100 mm
Max Resolution (Colour)
300 x 300 dpi
USB, USB host, Wi-Fi
AirPrint Enabled
Preview Screen Size
2.7"
Card Reader
Media Type
Postcards
Printer Features
Borderless printing, smooth skin, 100 Years Print, My Colors, Auto Power Off, Red-Eye Correction
Apple MacOS, Android, Microsoft Windows 7 SP1, Windows 8, Apple iOS, Windows 8.1
Enclosure Colour
18.06 cm x 13.59 cm x 6.33 cm
Printer Type
Enclosure Colour
Printer
Print Speed
Built-in Devices
Preview screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
300 x 300 dpi
Direct Printing Specifications
PictBridge, DPOF
Printer Features
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Media Handling
Media Type
Postcards
Max Media Size
148 x 100 mm
100 mm x 148 mm
100 mm x 148 mm
Media Sizes
148 x 100 mm
Media Feeders
1 x automatic
1 x USB - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Paper cassette
Power adapter - external
60 Watt
Power Consumption Stand by
4 Watt
Software Included
Drivers & Utilities
5 °C
20 - 80%
18.06 cm
13.59 cm
6.33 cm
860 g
Ink (1)
CDLJ Canon KP 36IP Print Cartridge/Paper Kit - 36 sheets In Stock £12.42
Other bundles (9)
CDLJ C2G 2m USB 2.0 A/B Cable - Black In Stock £3.11
CDLJ C2G 5m USB 2.0 A/B Cable - Black In Stock £4.51
CDLJ C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.76
CDLJ C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
CDLJ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.73
CDLJ C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.28
CDLJ C2G USB Superbooster Extender Kit In Stock £37.81
CDLJ C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.38
CDLJ C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
