Family vacations, parties, and special moments - the PowerShot SX720 HS camera is ready for it all. Its fantastically versatile 40x optical zoom means you can capture close-up portraits of your family, landmarks in the distance and virtually everything in between. While you're away, keep those at home updated on your travels by sharing your shots with the PowerShot SX720 HS's built-in Wi-Fi and NFC connectivity. Your memories are precious, so whether you're snapping a picture of the sunset, capturing fun outings with friends or shooting a home movie to treasure for a lifetime, a 20.3 MP CMOS sensor brings you stunning images and spectacular Full HD video.
Powerful 40x optical zoom with Intelligent IS helps optimize image stabilization
With the PowerShot SX720 HS camera in hand, you'll be impressed at the zooming capabilities of this slim, compact digital camera. The amazing 40x optical zoom lens, pack a lot of zoom power into a slim design. The camera's advanced technology helps ensure that images and videos are captured with outstanding quality. -
Built-in Wi-Fi technology makes sharing quick and easy
Built-in Wi-Fi technology allows for on-the-go convenience when you want to share your photos and videos with friends and family. Easily post your images in social networking and media. You can control the destination of your uploads to share with everyone or to selected groups, and even add comments. -
Built-in NFC technology
PowerShot digital cameras with built-in NFC technology provide fast connectivity for quick, easy sharing of your images. Even if your camera is off, NFC turns the camera on and establishes the connection.
- Canon PowerShot SX720 HS - digital camera
- Product Type
- Digital camera - 1080p - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 6
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 20.3 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 40x zoom - 4.3 - 172 mm - f/3.3-6.9
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 5 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Intelligent IS with 5-axis Advanced Dynamic Mode)
- Camera Flash
- Pop-up flash
- Display
- LCD display - 3"
- Supported Battery
- Canon NB-13L Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 10.97 cm x 3.57 cm x 6.38 cm
- 270 g
- Product Type
- Enclosure Colour
- Black
- Sensor Resolution
- 20.3 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 21,100,000 pixels
- Effective Sensor Resolution
- 20,300,000 pixels
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 60 fps
- ISO (Max)
- 3200
- Optical Zoom
- 40x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 6
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Subject-tracking AF
- Face Detection
- Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
- Digital Video Format
- H.264, iFrame
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Auto Focus Features
- Focus Peaking function
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Computer Connectivity
- Mac, Windows
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Portrait mode, fireworks, low light, sports mode, smart shutter, handheld night scene
- Special Effects
- Black & White, Sepia, Neutral, Vivid, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, Toy camera, Posterisation, Super Vivid
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
- Max Shutter Speed
- 1/3200 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
- X-sync Speed
- 1/2000 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 960mm
- Focus Adjustment
- Automatic, manual
- 5 cm
- Macro Focus Range
- 1-50cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 10 groups / 13 elements
- UD glass, built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Pop-up flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- Flash +/- compensation
- Effective Flash Range
- 0.5 m - 4 m (wide lens) , 2 m (tele lens)
Additional Features
- Continuous Shooting Speed
- 4.6 frames per second, 5.9 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, cropping an image, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, digital tele-converter, USB charging, Smart Flash Exposure, HS System, Zoom Framing Assist, Smart AUTO, Live View Control, GPS via mobile, Hybrid Auto
Display
- 3" LCD display
- Display Format
- 922,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 (mini-USB Type B) , HDMI output (19 pin micro HDMI Type D) , Composite video/audio output
- Included Accessories
- Battery charger, wrist strap
- Battery Type
- Canon NB-13L Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 250 shots , Photo shooting - 355 shots (ECO mode) , Playback - 5 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
- Video Capture
- H.264 - 1920 x 1080 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps , H.264 - 640 x 480 p - 30 fps
- 10.97 cm
- 3.57 cm
- 6.38 cm
- 270 g
- 0 °C
- 40 °C
- 10 - 90%
