Canon PowerShot SX720 HS Camera Black
Quicklinx: C2QRWS00 Mfr#: 1070C014AA
  • microSD Card
Family vacations, parties, and special moments - the PowerShot SX720 HS camera is ready for it all. Its fantastically versatile 40x optical zoom means you can capture close-up portraits of your family, landmarks in the distance and virtually everything in between. While you're away, keep those at home updated on your travels by sharing your shots with the PowerShot SX720 HS's built-in Wi-Fi and NFC connectivity. Your memories are precious, so whether you're snapping a picture of the sunset, capturing fun outings with friends or shooting a home movie to treasure for a lifetime, a 20.3 MP CMOS sensor brings you stunning images and spectacular Full HD video.
  • Powerful 40x optical zoom with Intelligent IS helps optimize image stabilization
    With the PowerShot SX720 HS camera in hand, you'll be impressed at the zooming capabilities of this slim, compact digital camera. The amazing 40x optical zoom lens, pack a lot of zoom power into a slim design. The camera's advanced technology helps ensure that images and videos are captured with outstanding quality.
  • Built-in Wi-Fi technology makes sharing quick and easy
    Built-in Wi-Fi technology allows for on-the-go convenience when you want to share your photos and videos with friends and family. Easily post your images in social networking and media. You can control the destination of your uploads to share with everyone or to selected groups, and even add comments.
  • Built-in NFC technology
    PowerShot digital cameras with built-in NFC technology provide fast connectivity for quick, easy sharing of your images. Even if your camera is off, NFC turns the camera on and establishes the connection.
Canon PowerShot SX720 HS - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
20.3 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 40x zoom - 4.3 - 172 mm - f/3.3-6.9
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Advanced Dynamic Mode)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Canon NB-13L Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
10.97 cm x 3.57 cm x 6.38 cm
270 g
Enclosure Colour
Sensor Resolution
20.3 Megapixel
Optical Sensor Type
CMOS
Total Pixels
21,100,000 pixels
Effective Sensor Resolution
20,300,000 pixels
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
60 fps
ISO (Max)
3200
Optical Zoom
40x
Digital Zoom
4x
Image Processor
DIGIC 6
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
Digital Video Format
H.264, iFrame
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Auto Focus Features
Focus Peaking function
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Computer Connectivity
Mac, Windows
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Portrait mode, fireworks, low light, sports mode, smart shutter, handheld night scene
Special Effects
Black & White, Sepia, Neutral, Vivid, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, Toy camera, Posterisation, Super Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
Max Shutter Speed
1/3200 sec
Min Shutter Speed
15 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
X-sync Speed
1/2000 sec
Lens System
Focal Length Equivalent to 35mm Camera
24 - 960mm
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Macro Focus Range
1-50cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 13 elements
UD glass, built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Flash +/- compensation
Effective Flash Range
0.5 m - 4 m (wide lens) , 2 m (tele lens)
Additional Features
Continuous Shooting Speed
4.6 frames per second, 5.9 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, cropping an image, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, digital tele-converter, USB charging, Smart Flash Exposure, HS System, Zoom Framing Assist, Smart AUTO, Live View Control, GPS via mobile, Hybrid Auto
Display
3" LCD display
Display Format
922,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 (mini-USB Type B) , HDMI output (19 pin micro HDMI Type D) , Composite video/audio output
Battery charger, wrist strap
Battery Type
Canon NB-13L Lithium Ion
Details
Battery Life Details
Photo shooting - 250 shots , Photo shooting - 355 shots (ECO mode) , Playback - 5 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Memory Card Included
No
Image Storage
JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps , H.264 - 640 x 480 p - 30 fps
10.97 cm
3.57 cm
6.38 cm
270 g
10 - 90%
