Canon PowerShot SX710 HS Red 20.3MP 30xZoom 3.0LCD FHD 25mm Wide
Quicklinx: B7TXWS00 Mfr#: 0110C011AA
For capturing everything from vacation videos to everyday snaps, you'll want the high-zoom, compact-body PowerShot SX710 HS camera by your side. Powerfully advanced yet easy to use, this camera is prepared to handle a variety of situations. The amazing optical zoom gives you the versatility you need to take your still images and breathtaking video to the next level, with Intelligent IS and Zoom Framing Assist to keep even your high zoom shots clear and steady. Built-in Wi-Fi and NFC make sharing what you've captured simple. This camera is perfect for travelers, families, and anyone who appreciates superb quality and performance.
  • Great optical zoom
    Optical zoom helps facilitate versatility while maintaining outstanding optical performance, along with Intelligent IS to help optimize image stabilization for virtually shake-free images in a wide variety of conditions.
  • Built-in Wi-Fi and NFC
    Built-in Wi-Fi allows wireless transferring of images and video to compatible mobile devices, select social networking sites and your Wi-Fi enabled computer, and lets you remotely shoot using your compatible smartphone or tablet, while built-in NFC (Near Field Communication) allows quick and simple pairing to a compatible device.
  • Large LCD
    Large LCD with a high screen resolution allows easy viewing even from a wide angle.
  • Zoom Framing Assist
    With Zoom Framing Assist, your camera will automatically zoom in or out while following the movement of your subject and help it to remain in focus.
  • Hybrid Auto
    Hybrid Auto records quick video clips before each still and compiles them together to make a short highlight reel, while Smart AUTO intelligently selects the proper settings for the camera based on predefined shooting situations to help you create amazing image.
  • High speed AF
    The PowerShot SX710 HS camera is equipped with Canon's great advancements in autofocus (AF) technology. Canon's advanced AF achieves a significant increase in speed for a shooting experience that's spontaneous and natural. The remarkably responsive High speed AF lets you capture great shots as they happen, with reduced lag time.
  • Full resolution continuous shooting
    Powered by the advanced DIGIC 6 image processor, the PowerShot SX710 HS camera gives you continuous shooting at the camera's full resolution. This lets you freeze action with stunning clarity to create spectacular images.
Canon PowerShot SX710 HS - digital camera
Digital camera - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
20.3 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 30x zoom - 4.5 - 135 mm - f/3.2-6.9
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Canon NB-6LH Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Red
11.27 cm x 3.48 cm x 6.58 cm
269 g
Enclosure Colour
Red
Sensor Resolution
20.3 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
21,100,000 pixels
Effective Sensor Resolution
20,300,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
3200
Optical Zoom
30x
Digital Zoom
4x
Image Processor
DIGIC 6
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
Digital Video Format
H.264, iFrame
Image Recording Format
JPEG
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Portrait mode, fireworks, low light, sports mode, snow, handheld night scene
Special Effects
Black & White, Sepia, Neutral, Vivid, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, Toy camera, Posterisation, Super Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
Max Shutter Speed
1/3200 sec
Min Shutter Speed
15 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
X-sync Speed
1/2000 sec
Lens System
Focal Length Equivalent to 35mm Camera
25 - 750mm
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Macro Focus Range
1-50cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 13 elements
UD glass, built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.5 m - 3.5 m (wide lens) , 1.4 m - 2 m (tele lens)
Additional Features
Continuous Shooting Speed
4.5 frames per second, 6 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, digital tele-converter, Smart Flash Exposure, HS System, Zoom Framing Assist, Smart AUTO, Live View Control, GPS via mobile, Hybrid Auto
Display
3" LCD display
Display Format
922,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
Software
Drivers & Utilities, Canon CameraWindow, Canon Map Utility, Canon Image Transfer Utility
Battery charger, wrist strap
Battery Type
Canon NB-6LH Lithium Ion
Details
Battery Life Details
Photo shooting - 230 shots , Photo shooting - 315 shots (ECO mode) , Playback - 4 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 - 60 fps , H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps
11.27 cm
3.48 cm
6.58 cm
269 g
10 - 90%
