For capturing everything from vacation videos to everyday snaps, you'll want the high-zoom, compact-body PowerShot SX710 HS camera by your side. Powerfully advanced yet easy to use, this camera is prepared to handle a variety of situations. The amazing optical zoom gives you the versatility you need to take your still images and breathtaking video to the next level, with Intelligent IS and Zoom Framing Assist to keep even your high zoom shots clear and steady. Built-in Wi-Fi and NFC make sharing what you've captured simple. This camera is perfect for travelers, families, and anyone who appreciates superb quality and performance.
Great optical zoom
Optical zoom helps facilitate versatility while maintaining outstanding optical performance, along with Intelligent IS to help optimize image stabilization for virtually shake-free images in a wide variety of conditions. -
Built-in Wi-Fi allows wireless transferring of images and video to compatible mobile devices, select social networking sites and your Wi-Fi enabled computer, and lets you remotely shoot using your compatible smartphone or tablet, while built-in NFC (Near Field Communication) allows quick and simple pairing to a compatible device. -
Large LCD
Large LCD with a high screen resolution allows easy viewing even from a wide angle. -
Zoom Framing Assist
With Zoom Framing Assist, your camera will automatically zoom in or out while following the movement of your subject and help it to remain in focus. -
Hybrid Auto
Hybrid Auto records quick video clips before each still and compiles them together to make a short highlight reel, while Smart AUTO intelligently selects the proper settings for the camera based on predefined shooting situations to help you create amazing image. -
High speed AF
The PowerShot SX710 HS camera is equipped with Canon's great advancements in autofocus (AF) technology. Canon's advanced AF achieves a significant increase in speed for a shooting experience that's spontaneous and natural. The remarkably responsive High speed AF lets you capture great shots as they happen, with reduced lag time. -
Full resolution continuous shooting
Powered by the advanced DIGIC 6 image processor, the PowerShot SX710 HS camera gives you continuous shooting at the camera's full resolution. This lets you freeze action with stunning clarity to create spectacular images.
- Canon PowerShot SX710 HS - digital camera
- Product Type
- Digital camera - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 6
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 20.3 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 30x zoom - 4.5 - 135 mm - f/3.2-6.9
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 1 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
- Camera Flash
- Pop-up flash
- Display
- LCD display - 3"
- Supported Battery
- Canon NB-6LH Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Red
- 11.27 cm x 3.48 cm x 6.58 cm
- 269 g
- Product Type
- Enclosure Colour
- Red
- Sensor Resolution
- 20.3 Megapixel
- Optical Sensor Type
- BSI-CMOS
- Total Pixels
- 21,100,000 pixels
- Effective Sensor Resolution
- 20,300,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 3200
- Optical Zoom
- 30x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 6
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Subject-tracking AF
- Face Detection
- Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
- Digital Video Format
- H.264, iFrame
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Connectivity Features
- Remote control via mobile devices
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Portrait mode, fireworks, low light, sports mode, snow, handheld night scene
- Special Effects
- Black & White, Sepia, Neutral, Vivid, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, Toy camera, Posterisation, Super Vivid
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
- Max Shutter Speed
- 1/3200 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
- X-sync Speed
- 1/2000 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 25 - 750mm
- Focus Adjustment
- Automatic, manual
- 1 cm
- Macro Focus Range
- 1-50cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 10 groups / 13 elements
- UD glass, built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Pop-up flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.5 m - 3.5 m (wide lens) , 1.4 m - 2 m (tele lens)
Additional Features
- Continuous Shooting Speed
- 4.5 frames per second, 6 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, digital tele-converter, Smart Flash Exposure, HS System, Zoom Framing Assist, Smart AUTO, Live View Control, GPS via mobile, Hybrid Auto
Display
- 3" LCD display
- Display Format
- 922,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
- Software
- Drivers & Utilities, Canon CameraWindow, Canon Map Utility, Canon Image Transfer Utility
- Included Accessories
- Battery charger, wrist strap
- Battery Type
- Canon NB-6LH Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 230 shots , Photo shooting - 315 shots (ECO mode) , Playback - 4 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Image Storage
- JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
- Video Capture
- H.264 - 1920 x 1080 - 60 fps , H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps
- 11.27 cm
- 3.48 cm
- 6.58 cm
- 269 g
- 0 °C
- 40 °C
- 10 - 90%
