Canon PowerShot G9X Camera Black
Quicklinx: C2QYWS00 Mfr#: 0511C011AA
Expert quality in a camera you will hardly notice is there. Slim and beautifully crafted, with as much or as little control as you like, it puts simple creative expression and premium quality results in the palm of your hand.
  • Beautifully crafted
    Slim and beautifully crafted compact design that's even smaller than the PowerShot G7 X and puts premium image quality in your pocket.
  • Superb shots in any light
    Crisp, clear shots even in any light thanks to Canon's HS System, with large 1.0-type 20.2 Megapixel CMOS sensor and powerful DIGIC 6 processor, and premium Canon optics featuring a superbly bright f/2.0 lens and 3x optical zoom.
  • Optical Image Stabilizer
    An Intelligent optical Image Stabilizer delivers beautifully crisp and steady shots in stills and movies - even handheld or in low light.
  • Effortless sharing
    Easily share photos and movies using Dynamic NFC and Wi-Fi to instantly connect your camera to your smartphone or tablet with just one tap.
  • Remote shooting
    Shoot remotely from your smartphone, with full creative control and Touch AF, using the Canon Camera Connect app - great for capturing group shots or wildlife.
  • Simple image back up
    Automatically back up your images to cloud services like Flickr, Google Drive and irista via Wi-Fi with Image Sync.
  • Versatile charging
    Easily charge your camera via standard USB smartphone chargers or via your PC while working or surfing the internet.
  • Easy creativity
    Enjoy creative control with a customizable Lens Control Ring and minimalist button layout.
  • Touchscreen
    Enjoy intuitive fingertip operation with a large 3.0" (1040K dots) touchscreen.
  • RAW support
    14-bit RAW file support further increases your creative options during photo editing.
Canon PowerShot G9 X - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
20.2 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 10.2 - 30.6 mm - f/2.0-4.9
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery (included)
HDMI, USB 2.0
9.8 cm x 3.08 cm x 5.79 cm
209 g
Enclosure Colour
Sensor Resolution
20.2 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
20,900,000 pixels
Effective Sensor Resolution
20,200,000 pixels
Optical Sensor Size
1.0"
Frame Rate (Max Resolution)
59.94 fps
ISO (Max)
12800
Optical Zoom
3x
Digital Zoom
4x
Image Processor
DIGIC 6
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
31
AE/AF Control
Face-priority AF, Subject-tracking AF, Touch Area AF
Digital Video Format
H.264, iFrame, AVC
Image Recording Format
JPEG, RAW
1920 x 1080
HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via Android devices, remote control via iPhone / iPad / iPod Touch, remote live view
Exposure & White Balance
Light Sensitivity
ISO 800, ISO 125, ISO 400, ISO 200, ISO 320, ISO 640, ISO 500, ISO 250, ISO 1600, ISO 6400, ISO 3200, ISO 1000, ISO 1250, ISO auto (100-12800), ISO 2000, ISO 2500, ISO 4000, ISO 1200, ISO 5000, ISO 12800, ISO 10000, ISO 8000
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Scene, fireworks, super vivid, poster effect, high dynamic, fisheye effect, miniature effect, toy camera effect, soft focus, monochrome, creative shot, handheld night scene
Special Effects
Black & White, Sepia, Neutral, Vivid, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, Positive Film
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade, Underwater, fluorescent light (daylight colour)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/3 EV step
X-sync Speed
1/2000 sec
Lens System
Focal Length Equivalent to 35mm Camera
28 - 84mm
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Zoom Adjustment
Motorised drive
Lens Construction
8 groups / 6 elements
Aspherical lens, UA lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation
Effective Flash Range
0.5 m - 6 m , 0.5 m - 2.4 m
Additional Features
Continuous Shooting Speed
4.3 frames per second, 6 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Audio recording, RGB primary colour filter, digital noise reduction, camera orientation detection, histogram display, AE lock, AF lock, FE lock, resizing an image, in-camera red-eye fix, digital tele-converter, safety zoom, GPS via mobile
Display
3" LCD display
Display Format
1,040,000 pixels
Display Form Factor
Built-in
Touch Screen
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB , HDMI (19 pin micro HDMI Type D)
Battery charger, neck strap, carrying case, AC power adaptor, USB cable
Battery Type
Canon NB-13L Lithium Ion
Details
Battery Life Details
Photo shooting - 220 shots , Photo shooting - 335 shots (ECO mode)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Memory Card Included
No
Image Storage
JPEG 5472 x 3648 , JPEG 4320 x 2880 , JPEG 2304 x 1536 , JPEG 720 x 480 , JPEG 4864 x 3648 , JPEG 3840 x 2880 , JPEG 2048 x 1536 , JPEG 640 x 480 , JPEG 5472 x 3080 , JPEG 4320 x 2432 , JPEG 1920 x 1080 , JPEG 720 x 408 , JPEG 3648 x 3648 , JPEG 2880 x 2880 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 - 59.94 fps , H.264 - 1920 x 1080 - 50 fps , H.264 - 1920 x 1080 - 29.97 fps , H.264 - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 23.98 fps , H.264 - 1280 x 720 - 29.97 fps , H.264 - 1280 x 720 - 25 fps , H.264 - 640 x 480 - 29.97 fps , H.264 - 640 x 480 - 25 fps
9.8 cm
3.08 cm
5.79 cm
209 g
10 - 90%
