Expert quality in a camera you will hardly notice is there. Slim and beautifully crafted, with as much or as little control as you like, it puts simple creative expression and premium quality results in the palm of your hand.
Beautifully crafted
Slim and beautifully crafted compact design that's even smaller than the PowerShot G7 X and puts premium image quality in your pocket. -
Superb shots in any light
Crisp, clear shots even in any light thanks to Canon's HS System, with large 1.0-type 20.2 Megapixel CMOS sensor and powerful DIGIC 6 processor, and premium Canon optics featuring a superbly bright f/2.0 lens and 3x optical zoom. -
Optical Image Stabilizer
An Intelligent optical Image Stabilizer delivers beautifully crisp and steady shots in stills and movies - even handheld or in low light. -
Effortless sharing
Easily share photos and movies using Dynamic NFC and Wi-Fi to instantly connect your camera to your smartphone or tablet with just one tap. -
Remote shooting
Shoot remotely from your smartphone, with full creative control and Touch AF, using the Canon Camera Connect app - great for capturing group shots or wildlife. -
Simple image back up
Automatically back up your images to cloud services like Flickr, Google Drive and irista via Wi-Fi with Image Sync. -
Versatile charging
Easily charge your camera via standard USB smartphone chargers or via your PC while working or surfing the internet. -
Easy creativity
Enjoy creative control with a customizable Lens Control Ring and minimalist button layout. -
Touchscreen
Enjoy intuitive fingertip operation with a large 3.0" (1040K dots) touchscreen. -
RAW support
14-bit RAW file support further increases your creative options during photo editing.
- Canon PowerShot G9 X - digital camera
- Product Type
- Digital camera - 1080p - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 6
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 20.2 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 3x zoom - 10.2 - 30.6 mm - f/2.0-4.9
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 5 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
- Camera Flash
- Pop-up flash
- Display
- LCD display - 3"
- Supported Battery
- Li-ion rechargeable battery (included)
- Interface
- HDMI, USB 2.0
- Black
- 9.8 cm x 3.08 cm x 5.79 cm
- 209 g
- Product Type
- Enclosure Colour
- Black
- Sensor Resolution
- 20.2 Megapixel
- Optical Sensor Type
- BSI-CMOS
- Total Pixels
- 20,900,000 pixels
- Effective Sensor Resolution
- 20,200,000 pixels
- Optical Sensor Size
- 1.0"
- Frame Rate (Max Resolution)
- 59.94 fps
- ISO (Max)
- 12800
- Optical Zoom
- 3x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 6
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 31
- AE/AF Control
- Face-priority AF, Subject-tracking AF, Touch Area AF
- Digital Video Format
- H.264, iFrame, AVC
- Image Recording Format
- JPEG, RAW
- 1920 x 1080
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Connectivity Features
- Remote control via Android devices, remote control via iPhone / iPad / iPod Touch, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 800, ISO 125, ISO 400, ISO 200, ISO 320, ISO 640, ISO 500, ISO 250, ISO 1600, ISO 6400, ISO 3200, ISO 1000, ISO 1250, ISO auto (100-12800), ISO 2000, ISO 2500, ISO 4000, ISO 1200, ISO 5000, ISO 12800, ISO 10000, ISO 8000
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Scene, fireworks, super vivid, poster effect, high dynamic, fisheye effect, miniature effect, toy camera effect, soft focus, monochrome, creative shot, handheld night scene
- Special Effects
- Black & White, Sepia, Neutral, Vivid, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, Positive Film
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, Flash, daylight, shade, Underwater, fluorescent light (daylight colour)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±3 EV range, in 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/3 EV step
- X-sync Speed
- 1/2000 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 28 - 84mm
- Focus Adjustment
- Automatic, manual
- 5 cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 8 groups / 6 elements
- Aspherical lens, UA lens
Camera Flash
- Camera Flash
- Pop-up flash
- Flash Modes
- Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation
- Effective Flash Range
- 0.5 m - 6 m , 0.5 m - 2.4 m
Additional Features
- Continuous Shooting Speed
- 4.3 frames per second, 6 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Audio recording, RGB primary colour filter, digital noise reduction, camera orientation detection, histogram display, AE lock, AF lock, FE lock, resizing an image, in-camera red-eye fix, digital tele-converter, safety zoom, GPS via mobile
Display
- 3" LCD display
- Display Format
- 1,040,000 pixels
- Display Form Factor
- Built-in
- Touch Screen
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB , HDMI (19 pin micro HDMI Type D)
- Included Accessories
- Battery charger, neck strap, carrying case, AC power adaptor, USB cable
- Battery Type
- Canon NB-13L Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 220 shots , Photo shooting - 335 shots (ECO mode)
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 5472 x 3648 , JPEG 4320 x 2880 , JPEG 2304 x 1536 , JPEG 720 x 480 , JPEG 4864 x 3648 , JPEG 3840 x 2880 , JPEG 2048 x 1536 , JPEG 640 x 480 , JPEG 5472 x 3080 , JPEG 4320 x 2432 , JPEG 1920 x 1080 , JPEG 720 x 408 , JPEG 3648 x 3648 , JPEG 2880 x 2880 , JPEG 1536 x 1536 , JPEG 480 x 480
- Video Capture
- H.264 - 1920 x 1080 - 59.94 fps , H.264 - 1920 x 1080 - 50 fps , H.264 - 1920 x 1080 - 29.97 fps , H.264 - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 23.98 fps , H.264 - 1280 x 720 - 29.97 fps , H.264 - 1280 x 720 - 25 fps , H.264 - 640 x 480 - 29.97 fps , H.264 - 640 x 480 - 25 fps
- 9.8 cm
- 3.08 cm
- 5.79 cm
- 209 g
- 0 °C
- 40 °C
- 10 - 90%
