Canon Powershot G1X II Camera Black 15MP 4xZoom Touch 3.0 LCD
Quicklinx: 9XK7WS00 Mfr#: 9167B012AA
  • SDHC Memory Card
The PowerShot G1 X Mark II raises performance and quality to new heights in a compact, brilliant design. Featuring a huge, 1.5-inch 12.8 Megapixel High-Sensitivity CMOS sensor, a powerful DIGIC 6 Image Processor and a 5x wide-angle optical zoom lens with Optical Image Stabilizer and a circular, 9-blade aperture for stunning blurred backgrounds, the PowerShot G1 X Mark II delivers the outstanding image quality you would expect with a digital SLR camera but in a portable, Wi-Fi and NFC enabled package. It can capture 14-bit RAW plus JPEG images, features a staggering 31 focus points for speedy and accurate AF, a capacitive 3.0-inch tilt-type touch panel LCD and has newly developed Dual Control Rings on the lens barrel for fast control of exposure and focus. An optional high-resolution electronic viewfinder adds to the camera's professional feel and functionality. Whether being used as a companion to an EOS digital SLR or as a standalone camera, the PowerShot G1 X Mark II has the power to handle most any photographic situation it encounters.
  • Canon 1.5-inch, 12.8 megapixel high-sensitivity CMOS sensor
    Almost as large as the APS-C CMOS sensor found in many EOS digital SLRs, and bigger than those found in 4/3 system cameras, the PowerShot G1 X Mark II's sensor sets the standard for sensitivity and resolving power in compact cameras. Each cell area is 4.5x the size of those found in 1/1.7 type sensors and is thus able to capture more light at the pixel level. This means better detail, even at higher ISOs, with minimal noise and distortion and, thanks to the sensor's wide cell pitch, breathtaking dynamic range. The PowerShot G1 X Mark II camera natively captures images in the 3:2 aspect ratio, which is the same as Canon EOS SLR cameras. The PowerShot G1 X Mark II also features a new Aspect Ratio function, enabling RAW image capture in both 3:2 and 4:3 aspect ratios while maintaining the same angle of view.
  • Canon DIGIC 6 image processor
    The PowerShot G1 X Mark II camera is equipped with the very latest Canon proprietary processor, the DIGIC 6 Image Processor, which makes several important advancements to image quality both in stills and video. Improved light sensitivity allows for higher resolution with less noise when shooting in dark conditions, and Dynamic IS now detects and compensates for tilt and parallel movement (shift blur) to create video that's exceptionally free of distortion. The DIGIC 6 Image Processor also enhances the performance capabilities of the PowerShot G1 X Mark II, powering full resolution high-speed continuous still shooting and the advanced Star shooting modes. Video recording has also been improved with MP4 recording for better compatibility with mobile devices and tablets. Highly compressed MP4 video not only preserves space on your memory card but also improves playback on mobile devices. Plus, with MF Peaking possible thanks to the new processor, you'll have a pro-level focusing tool at your disposal.
  • Canon HS SYSTEM
    The Canon HS SYSTEM lets you take bright, clear photos in an even wider range of shooting situations. Beautiful low-light shots are possible with minimal noise and maximum detail in highlight and shadow areas. The system is the result of two technologies in the PowerShot G1 X Mark II: the amazing 1.5-inch High-Sensitivity CMOS imaging sensor, which is able to capture more light; and the DIGIC 6 Image Processor, which actively reduces noise at high ISO speeds and processes images at high speed, even at full resolution. Thus, the Canon HS SYSTEM allows you to use higher shutter speeds to capture clearer images with reduced noise and blur in more situations.
Canon PowerShot G1 X Mark II - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
12.8 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 5x zoom - 12.5 - 62.5 mm - f/2.0-3.9
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Canon NB-12L Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
11.63 cm x 6.62 cm x 7.4 cm
558 g
Sensor Resolution
12.8 Megapixel
Optical Sensor Type
CMOS
Total Pixels
15,000,000 pixels
Effective Sensor Resolution
12,800,000 pixels
Optical Sensor Size
G1X (18.7 x 14 mm)
ISO (Max)
12800
Optical Zoom
5x
Digital Zoom
4x
Image Processor
DIGIC 6
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
HDR Mode
Auto HDR mode
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
31
AE/AF Control
Face-priority AF, Subject-tracking AF, Touch Area AF
Face Detection
Blink Detection technology, Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
Digital Video Format
H.264, iFrame
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 125, ISO 400, ISO 200, ISO 160, ISO 320, ISO 640, ISO 500, ISO 250, ISO 1600, ISO 6400, ISO 3200, ISO 1000, ISO 1250, ISO auto, ISO 2000, ISO 2500, ISO 4000, ISO 5000, ISO 12800, ISO 10000, ISO 8000
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, fireworks, Underwater, snow, smart shutter, star nightscape, star trails, star time-lapse movie, handheld night scene, star portrait
Special Effects
Black & White, Sepia, Neutral, Vivid, Custom Effect, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, HDR, Toy camera, Nostalgic, Posterisation, Super Vivid, Background defocus
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, fluorescent light (cool white), Underwater
Max Shutter Speed
1/4000 sec
Min Shutter Speed
60 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
X-sync Speed
1/2000 sec, 1/250sec, 1/4000 sec
Lens System
Focal Length Equivalent to 35mm Camera
24 - 120mm
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Lens Construction
11 groups / 14 elements
Built-in lens shield, aspherical lens, UA lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation
Effective Flash Range
0.5 m - 6.8 m (wide lens) , 0.5 m - 3.5 m (tele lens)
Additional Features
Continuous Shooting Speed
3 frames per second, 3.1 frames per second, 5.2 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, histogram display, AE lock, AF lock, FE lock, cropping an image, resizing an image, Scene Detection Technology, in-camera red-eye fix, in-camera film editing, digital tele-converter, safety zoom, HS System, Smart AUTO, GPS via mobile, Hybrid Auto
Display
3" LCD display
Display Format
1,040,000 pixels
Display Form Factor
Folding
Display Features
Contrast control, display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
USB 2.0 , Composite video/audio output , HDMI output
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon Digital Photo Professional, Canon ImageBrowser EX, Canon CameraWindow, Canon Map Utility
Battery charger, neck strap
Battery Type
Canon NB-12L Lithium Ion
Details
Battery Life Details
Photo shooting - 240 shots , Photo shooting - 300 shots (ECO mode) , Playback - 5 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
RAW 4352 x 2904 , RAW 4160 x 3120 , RAW 4352 x 2448 , JPEG 4352 x 2904 , JPEG 4160 x 3120 , JPEG 4352 x 2448 , JPEG 3072 x 2048 , JPEG 3072 x 2304 , JPEG 3072 x 1728 , JPEG 2048 x 1368 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , RAW 3120 x 3120 , JPEG 3120 x 3120 , JPEG 2304 x 2304 , JPEG 1536 x 1536 , JPEG 480 x 480 , RAW 2496 x 3120 , JPEG 2496 x 3120 , JPEG 1840 x 2304 , JPEG 1232 x 1536 , JPEG 384 x 480
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps , H.264 - 1280 x 720 - 6 fps - Miniature Effect , H.264 - 1280 x 720 - 3 fps - Miniature Effect , H.264 - 1280 x 720 - 1.5 fps - Miniature Effect , H.264 - 640 x 480 - 6 fps - Miniature Effect , H.264 - 640 x 480 - 3 fps - Miniature Effect , H.264 - 640 x 480 - 1.5 fps - Miniature Effect
11.63 cm
6.62 cm
7.4 cm
558 g
10 - 90%
