- Canon PIXMA TS6051 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
- Max Copying Speed
- 6.5 ppm (colour)
- Max Printing Speed
- Up to 15 ipm (mono) / up to 10 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 3"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
- Standard Media Capacity
- 120 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 37.2 cm x 31.5 cm x 13.9 cm
- 6.2 kg
- Enclosure Colour
- White
- Ink-jet - colour
- Display Diagonal Size
- 3"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Enclosure Colour
- White
Copying
- Max Copying Speed
- 6.5 ppm (colour)
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, Borderless copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, pigment black
- 5-ink
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- 120 sheets
- Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m² , Input tray - 20 sheets size: 100 x 150 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m²
- Speed Details
- Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 39 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 6.5 ipm - colour , Scanning: 19 sec (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows RT, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 - 10.11
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
- Voltage Required
- 13 Watt
- Power Consumption Standby
- 1.4 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 19 sec
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
- 37.2 cm
- 31.5 cm
- 13.9 cm
- 6.2 kg
- Sound Emission
- 47 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
