Canon PIXMA TS3450 Wireless Inkjet Multifunction Printer
Quicklinx: GTXXWS00 Mfr#: 4463C008AA
Print, copy and scan with the entry-level multifunction printer for home and office. It's super-simple to set up and use, and allows smartphone printing for extra versatility.
The PIXMA TS3450 is a compact and easy-to-use printer, scanner and copier. It’s simple to set up, with wireless connection at the touch of a button. Control it remotely with the latest technology: you can copy, scan or print from smartphone and tablet using the Canon PRINT app, or print app-free with AirPrint (iOS) and Mopria (Android). Access Point Mode allows you to connect your device directly to the printer without the need for an internet connection or router. Keep your documents crisp and images bright with FINE cartridges, and get creative with the Easy-PhotoPrint Editor app and Canon Creative Park. This all-in-one inkjet printer is an ideal first printer, with essential features at an affordable price.
  • Smart simplicity
    With a compact, modern design and excellent value, you can print, scan and copy effortlessly. It's so easy!
  • Compatible with your tech
    You can print, copy and scan from your tablet or smartphone, with wireless compatibility and clean, simple interface.
  • Super-simple setup
    You'll be up and running in less time than ever with one-touch wireless connectivity and an easier setup procedure.
  • Seeing is believing
    Status updates are shown in plain sight on the crystal-clear 1.5" mono segment LCD screen.
Canon PIXMA TS3450 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 7.7 ipm (mono) / up to 4 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
600 x 1200 dpi
Display
1.5"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
89 x 127 mm (min) - 215.9 x 676 mm (max)
Media Type
Plain paper, glossy photo paper, magnetic photo paper, restickable photo paper
Standard Media Capacity
60 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, access point mode
AC 120/230 V (50/60Hz)
43.5 cm x 32.7 cm x 14.5 cm
4 kg
Enclosure Colour
2 Years
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.5"
Display Colour Support
Monochrome
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Enclosure Colour
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
20
Copying Features
Fit to page, Borderless copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Supported Original Sizes
216 x 297 mm
Original Type
Sheets
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 130 x 130 mm, 215.9 x 676 mm
Borderless Photo Sizes
100 x 150 mm, 130 x 180 mm, 130 x 130 mm
60 sheets
Input tray - 60 sheets size: 89 x 127 mm - 215.9 x 676 mm weight: 64 g/m² - 275 g/m²
Speed Details
Printing: up to 7.7 ipm - B/W , Printing: up to 4 ipm - colour , Printing: 65 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 3 ipm
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Chrome OS, iPadOS, macOS 10.12.6 - macOS 10.15
Software Included
Drivers & Utilities, MP Driver including Scanning Utility, Canon Easy-PhotoPrint Editor
9 Watt
Power Consumption Standby
0.8 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (colour)
43.5 cm
32.7 cm
14.5 cm
4 kg
Sound Emission
48 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
2 Years
GTXX Canon CL546XL Colour High Yield Inkjet Cartridge In Stock £17.29
GTXX Canon PG545XL Black High Yield Inkjet Cartridge In Stock £17.93
