Simple, affordable and compact home printer for hassle-free, high-quality printing of vivid 4" x 6" photos and sharp documents.
Easy affordable everyday photo and document printing
With a compact, stylish design and simple USB connectivity, this everyday printer is a practical and cost effective choice for effortless printing of beautiful borderless 4" x 6" photos and high-quality documents at home. -
Compact and affordable
Compact, stylish and affordable with a durable easy-clean, patterned surface and Quiet mode - so you can enjoy near silent printing - this printer fits perfectly into any home. -
High-quality prints
Print vivid photos and documents with crisp text thanks to Canon's FINE technology and hybrid inks. Enjoy a 10 x 15 cm borderless image in seconds. -
Easy set up and control
Printer set up is easy with quick USB connectivity to your PC.
- Canon PIXMA TS205 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 2.5 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Media Size Class
- A4/Letter
- Max Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 7.7 ipm - B/W , Up to 4 ipm - colour
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- USB 2.0
- Media Type
- Plain paper, photo paper
- Total Media Capacity
- 60 sheets
- Printer Features
- Borderless printing, 100 Years Print
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 7 SP1, Windows 8.1 / 10, Apple macOS 10.12, Apple MacOS X 10.10.5 - 10.11
- 42.6 cm x 25.5 cm x 13.1 cm
- 2-year Limited Warranty
- Printer Type
Printer
- Inkjet Technology
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 4800 x 1200 dpi
- Printer Features
Media Handling
- Media Type
- Media Size Class
- A4/Letter
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm
- Borderless Photo Sizes
- 100 x 150 mm
- Media Weight
- 64 g/m² - 275 g/m²
- 60 sheets
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x ink cartridge (pigmented black) , 1 x ink cartridge (colour)
- ISO 24711, ISO/IEC 24734, ISO/IEC 29102
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 10 Watt
- Power Consumption Stand by
- 1.2 Watt
- Software Included
- Drivers & Utilities, Canon My Image Garden with Full HD Movie Print
- OS Required
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission (Operating)
- 46 dBA
- 42.6 cm
- 25.5 cm
- 13.1 cm
- 2.5 kg
Canon PG545 Black Ink Cartridge | In Stock | £12.64 |
Canon PG545XL Black High Yield Inkjet Cartridge | In Stock | £17.14 |
