Canon PIXMA TR8550 Inkjet
Quicklinx: D6N4WS00 Mfr#: 2233C008
Hurry, only 3 left in stock!
£108.33 ex VAT
£129.99 inc VAT
Boost home office productivity and save space using this premium 5-ink, 4-in-one, which packs print, scan, copy and fax functions, easy Wi-Fi, Ethernet and SD card connections plus smartphone-like touch control into a small, square design.
  • Smart, productive and fully connected 4-in-one
  • Quality prints, big savings
    Print superbly detailed color photos and sharp text in documents with 5 single inks. Save with optional XL or XXL ink tanks and auto 2-sided printing
  • Productive and versatile
    Effortlessly copy, scan or fax multi-page documents with the 20-sheet ADF and handle both plain and photo media with dual paper feeds. Scan and print ID cards with ease.
  • Small and effortless
    This space-saving 4-In-One has a beautifully small and square design with simple smartphone-like control from different angles using the 10.8 cm tilting color touchscreen.
Canon PIXMA TR8550 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
8 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 2400 dpi
Display
4.3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, glossy photo paper, matte photo paper, luster paper, semi-gloss photo paper
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link
AC 120/230 V (50/60Hz)
43.8 cm x 35.1 cm x 19 cm
8 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
4.3"
Colour Support
Display Features
Touch screen
AirPrint Enabled
PIXMA Cloud Link
Copying
Max Copying Speed
8 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, Borderless copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Ink Type
Canon ChromaLife100
Automatic Duplexing
Colour Management Features
Mopria
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
200 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 37 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 8 ipm - colour , Scanning: 15 sec (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, macOS 10.12, Apple Mac OS X 10.10.5 - 10.11, Windows Mobile
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
15 Watt
Power Consumption Standby
2 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
19 sec
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
43.8 cm
35.1 cm
19 cm
8 kg
Sound Emission
43 dBA (operating)
5 °C
35 °C
10 - 90% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 100 - 150
