Canon PIXMA TR7550 Colour Inkjet Multifunction Printer
Quicklinx: FRZWWS00 Mfr#: 2232C008
Small and compact, this PIXMA has smart mobile and cloud connections for productive print, copy, scan and fax in home and small offices.
  • Smart productive
    With smart connections to multiple devices, smartphone-like touch control and a space-saving design, this versatile PIXMA is ideal for productive print, scan, copy and fax functions in home offices.
  • Quality prints, big savings
    Print superbly detailed color photos and sharp text in documents. Save with auto 2-sided printing.
  • Small and effortless
    Space-saving device with a beautifully small and square design and effortless control via tilting an operation panel with a touchscreen and easy-access buttons.
Canon PIXMA TR7550 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
8 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 2400 dpi
Display
3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, glossy photo paper, matte photo paper, luster paper, semi-gloss photo paper
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n), Bluetooth LE
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link
AC 120/230 V (50/60Hz)
43.8 cm x 35 cm x 19 cm
8 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
PIXMA Cloud Link
Copying
Max Copying Speed
8 ppm (colour)
Maximum Copies
99
Copying Features
Fit to page, Borderless copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Ink Type
Canon ChromaLife100
Automatic Duplexing
Colour Management Features
Mopria
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
200 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 37 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 8 ipm - colour , Scanning: 15 sec (A4) - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, macOS 10.12, Apple Mac OS X 10.10.5 - 10.11
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
14 Watt
Power Consumption Standby
1.7 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
19 sec
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
43.8 cm
35 cm
19 cm
8 kg
5 °C
35 °C
10 - 90% (non-condensing)
