Canon Pixma TR4550 A4 Colour Innkjet Printer 8.8ipm Mono 4.4ipm Co
Quicklinx: FJR7WS00 Mfr#: 2984C008
This compact multifunctional printer benefits from effortless Wi-Fi and cloud connectivity - ideal for home offices.
  • Stylishly for home office use
    Compact and stylish, this multifunctional printer can copy, scan and fax multiple page documents. With high productivity and seamless wireless connectivity, it's a perfect fit for any home office.
  • Smart printer operation
    Wi-Fi connectivity gives you control of your printer functions from your smart devices.
Canon PIXMA TR4550 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Copying Speed
3.6 ppm (colour)
Max Printing Speed
Up to 8.8 ipm (mono) / up to 4.4 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
A3 (297 x 420 mm), 215.9 x 676 mm (max)
Media Type
Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, luster paper, semi-gloss photo paper, photo stickers
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, wireless direct printing, access point mode
AC 120/230 V (50/60Hz)
43.5 cm x 29.5 cm x 18.9 cm
5.9 kg
Enclosure Colour
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Features
LCD display
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Enclosure Colour
Copying
Max Copying Speed
3.6 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, fit to page, Frame Erase Copy, collation copy, Borderless copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Automatic Duplexing
Scanning
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Total Memory Capacity
Up to 50 pages
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 215.9 x 676 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
Input tray - 100 sheets size: 89 x 127 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m²
Speed Details
Printing: up to 8.8 ipm - B/W , Printing: up to 4.4 ipm - colour , Printing: 65 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 3.6 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.10.5 - 10.11, macOS 10.12 - macOS 10.13
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint EX, MP Driver including Scanning Utility
8 Watt
Power Consumption Standby
1.6 Watt
First Copy Out Time Colour
27 sec
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (colour)
43.5 cm
29.5 cm
18.9 cm
5.9 kg
Sound Emission
54 dBA (operating)
15 °C
30 °C
10 - 90% (non-condensing)
FJR7 Canon CL546XL Colour High Yield Inkjet Cartridge In Stock £17.29
FJR7 Canon PG545 Black Ink Cartridge In Stock £11.98
FJR7 Canon PG545XL Black High Yield Inkjet Cartridge In Stock £16.72
