Canon PIXMA PRO-100S Colour Inkjet A3 Printer
Quicklinx: CDLLWS00 Mfr#: 9984B008
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
£378.18 ex VAT
£453.81 inc VAT
This professional A3+ printer boasts an 8-ink dye based system for gallery-quality prints you'll be proud to display or sell, plus Wi-Fi and full cloud connectivity for easy integration with existing workflows.
Canon PIXMA PRO-100S - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
19.7 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
8-ink - cyan, magenta, yellow, photo cyan, photo magenta, light grey, black, grey
Max Media Size
A3 plus (329 x 423 mm), 360 x 430 mm
Max Media Size (Custom)
360 mm x 430 mm
Print Speed
Up to 0.57 min/page - photo - 101.6 x 152.4 mm , Up to 1.5 min/page - photo - A3 plus (329 x 423 mm)
Max Resolution (Colour)
4800 x 2400 dpi
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Media Type
Envelopes, plain paper, photo paper, photo stickers, glossy photo paper, fine art paper, matt photo paper, canvas paper, luster photo paper, DVD discs, CD discs, BD discs, semi-gloss photo paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray, CD/DVD tray, 1-sheet manual tray
Print server
Printer Features
Borderless printing, fit-to-page, Direct Disc Printing
AC 120/230 V
Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Android, Microsoft Windows 7 SP1, Windows 8, Apple iOS, Apple MacOS X 10.7.5 or later, Microsoft Windows XP (32-bit) SP3, Windows 8.1
Microsoft Certification
Compatible with Windows 7
68.9 cm x 38.5 cm x 21.5 cm
Printer Type
Printer
Inkjet Technology
Minimum Ink Droplet Size
3 pl
Ink Cartridge Configuration
8 individual ink tanks
Ink Type
Canon ChromaLife100+
Print Speed
Wireless
AirPrint Enabled
4800 x 2400 dpi
Direct Printing Specifications
PictBridge, Canon Direct Print
Printer Features
Media Handling
Media Handling
Media Type
Max Media Size
360 mm x 430 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, CD (120 mm), 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
Media Weight
64 g/m² - 350 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - A3 plus (329 x 423 mm) weight: 64 g/m² - 300 g/m² , 1 x automatic - 1 sheet - 360 x 430 mm 350 g/m² , 1 x automatic - CD (120 mm)
Print server
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x printhead , 1 x ink tank (black) , 1 x ink tank (grey) , 1 x ink tank (light grey) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow) , 1 x ink tank (photo cyan) , 1 x ink tank (photo magenta)
PIXMA Cloud Link
Power supply
AC 120/230 V
Frequency Required
50/60 Hz
19 Watt
Power Consumption Stand by
2.6 Watt
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Full HD Movie Print, Canon Color Management Tool Pro, Canon PrintStudioPro, Canon My Image Garden
5 °C
35 °C
10 - 90% (non-condensing)
Sound Emission (Operating)
38.5 dBA
68.9 cm
38.5 cm
21.5 cm
19.7 kg
CDLL C2G 2m USB 2.0 A/B Cable - Black In Stock £3.71
CDLL C2G 5m USB 2.0 A/B Cable - Black In Stock £4.92
CDLL C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.00
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: 34ppm
Max Paper Size: 360 x 430 mm
Max Paper Size: A3 plus (329 x 423 mm)
Brand: Canon
Price Range Ex VAT: 300 - 500
