High productivity, powerful Office All-In-One with Wi-Fi and XXL ink option
Powerful and productive 5-ink All-In-One offering XL and XXL ink options, Wi-Fi, Ethernet and 35-page 2-sided ADF. Advanced media handling with 250-sheet paper tray, 2-sided printing and Direct Disc Print.
- Powerful and productive Office All-In-One
- 35-page 2-sided Auto Document Feeder for scanning, copying and faxing
- Superior prints using 5 individual ink system with optional XL capacity ink tanks
- Print up to 1000 monochrome pages with optional XXL monochrome ink
- Convenient, high-capacity 250-sheet paper tray
- Large, user-friendly 7.5cm (3.0") colour TFT display with Dual Function Panel
- Fast printing with A4 ISO ESAT 15 ipm mono/10 ipm colour
- Print from, and scan to, smartphones/tablets. Apple AirPrint supported
- Google Cloud Print support and internet printing using PIXMA Cloud Link
- Advanced media handling with Direct Disc Print and 2-sided printing
Powerful and productive All-In-One
This premium, network-ready All-In-One delivers high productivity that everyone can share. Wi-Fi and Ethernet connectivity enable you to print, scan, copy and fax from virtually anywhere in the office or at home. Apple AirPrint support lets you print directly from iPad and iPhone.
Automatically scan, copy or fax large double-sided documents using the fully-integrated 35-page 2-sided Automatic Document Feeder. A high capacity 250-sheet tray means you spend less time loading paper, while automatic 2-sided printing reduces the amount of paper you use. Double front paper cassettes mean you can conveniently have two media types loaded at once, plus you can print directly onto printable discs using Direct Disc Print.
Economical, single ink tanks
For greater economy, this All-In-One features 5 single inks, so you only need to change the colour that runs out - making printing more efficient. Optional cost effective XL and XXL inks allow for more pages to be printed than a standard ink, so need replacing less frequently - ideal if you print a lot. XXL cartridge can print up to 1000 pages.
High quality, fast performance
Canon's FINE technology, with minimum 1pl ink droplets, delivers up to 9600dpi print resolution for amazingly detailed colour photos and images. Enjoy high print speeds of 15ipm mono or 10ipm colour. Print a photo-lab quality 10x15 cm borderless photo in approx. 21 seconds or copy an A4 page in just 12 seconds.
PIXMA Cloud Link
Print Google Docs, Gmails, photos and PDF attachments from virtually anywhere using Google Cloud Print. Produce calendars, download stationery and other templates direct from the PIXMA Cloud. Get more from your printer and print directly from the Internet. Print photos in seconds from CANON iMAGE GATEWAY or Google's Picasa online albums without a PC.
Smartphone and tablet ready
Canon's Easy-PhotoPrint app provides the flexibility to print from, or even scan to, your mobile devices wherever you are in the office. With Apple AirPrint support, you can also print photos, emails, web pages and other documents direct from your iPhone, iPad and iPod touch.
User-friendly operation
A large 7.5cm colour TFT display makes it easy to view selected functions and preview images. The Dual Function Panel features LED-lit dual-purpose keys. These keys change appearance according to the mode selected, simplifying feature navigation.
Powerful and productive all-in-one
This premium, network-ready all-in-one delivers high productivity that everyone can share. Wi-Fi and Ethernet connectivity enable you to print, scan, copy and fax from virtually anywhere in the office or at home. -
Automatically scan, copy or fax large double-sided documents using the fully-integrated 35-page 2-sided automatic document feeder. A high capacity 250-sheet tray means you spend less time loading paper, while automatic 2-sided printing reduces the amount of paper you use. Double front paper cassettes mean you can conveniently have two media types loaded at once, plus you can print directly onto printable discs using direct disc print. -
For greater economy, this all-in-one features 5 single inks, so you only need to change the color that runs out - making printing more efficient. -
Canon's FINE technology delivers up to 9600-dpi print resolution for amazingly detailed color photos and images. Enjoy high print speeds of 15 ipm mono or 10 ipm color. -
Canon's Easy-PhotoPrint app provides the flexibility to print from, or even scan to, your mobile devices wherever you are in the office. With Apple AirPrint support, you can also print photos, emails, web pages and other documents direct from your iPhone, iPad and iPod touch. -
A large 7.5 cm color TFT display makes it easy to view selected functions and preview images. The dual function panel features LED-lit dual-purpose keys.
- Canon PIXMA MX925 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
- Max Copying Speed
- 8.4 ppm (colour)
- Max Printing Speed
- Up to 15 ipm (mono) / up to 10 ipm (colour)
- Max Printing Resolution
- 9600 x 2400 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JPEG
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 2400 x 4800 dpi
- Display
- 3"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, printable CD/DVD/BD disk
- Standard Media Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, Fast Front
- Power
- AC 120/230 V (50/60Hz)
- 49.1 cm x 39.6 cm x 23.1 cm
- 11.7 kg
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Diagonal Size
- 3"
- Interface
- AirPrint Enabled
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- 8.4 ppm (colour)
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- BorderFree, fit to page, Preset Copy Ratios
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, pigment black
- 5-ink
- Minimum Ink Droplet Size
- 1 pl
- Ink Type
- Canon ChromaLife100+
Scanning
- Scan Element
- CIS
- Optical Resolution
- 2400 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JPEG
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 100 station(s)
- Telephone / Fax Switch
- Activity report, answering machine interface
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- 250 sheets
- ADF - 35 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 20 sheets - 130 x 180 mm , CD/DVD/BD tray
- Speed Details
- Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Copying: up to 8.4 ipm - colour , Printing: 21 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows XP, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6.8 or later, Windows 8, Windows RT, Windows 8 64-bit
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon Creative Park Premium, Canon My Image Garden
- Voltage Required
- 17 Watt
- Power Consumption Standby
- 1 Watt
- Power Consumption Sleep
- 0.4 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 12 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow) , 1 x ink tank (pigmented black)
- 49.1 cm
- 39.6 cm
- 23.1 cm
- 11.7 kg
- Sound Emission
- 44 dBA (operating)
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
Canon PGI-550PGBK XL - Pigment Black - Ink Cartridge | In Stock | £13.49 |
Canon CLI-551 XL Black Ink Cartridge | In Stock | £13.14 |
Canon CLI-551 XL Cyan Ink Cartridge | In Stock | £13.14 |
Canon CLI-551 XL Magenta Ink Cartridge | In Stock | £13.14 |
Canon CLI-551 XL Yellow Ink Cartridge | In Stock | £13.14 |
Canon CLI-551 XL Grey High Yield Ink Tank | In Stock | £13.14 |
Canon CLI-551 Black Ink Tank | In Stock | £9.68 |
Canon CLI-551 Grey Ink Tank | In Stock | £9.68 |
Canon CLI-551 Cyan Ink Tank | In Stock | £9.70 |
Canon CLI-551 Yellow Ink Tank | In Stock | £9.70 |
Canon CLI-551 Magenta Ink Tank | In Stock | £9.74 |
