Canon PIXMA MX725
Premium, high productivity 5-ink, All-In-One with Ethernet and Wi-Fi
A premium 5-ink wireless All-In-One featuring Ethernet, mobile and cloud connectivity plus a 35 sheet 2-sided ADF for highly productive printing, scanning, copying and faxing at home or in the office.
- Premium 5-ink All-In-One: print, copy, scan and fax
- Productive 250-sheet paper cassette and 2-sided 35 sheet ADF
- Easily share around the office with Wi-Fi and Ethernet connectivity
- Print from, and scan to mobile devices with PIXMA Printing Solutions app
- PIXMA Cloud Link, Google Cloud Print and Apple AirPrint support
Premium All-In-One
Stylish and productive this premium office All-In-One offers exceptional quality print, copy, scan and fax functions and is ideal for sharing between multiple PCs using either a wireless or Ethernet connection. Double front cassettes with 250-sheet capacity plus a fully-integrated 35-sheet 2-sided Automatic Document Feeder ensure maximum productivity.
Smart device and cloud printing
Download PIXMA Printing Solutions app and enjoy printing from, and scanning to, your smart devices over the Wi-Fi network. Directly from the printer screen you can browse and print photos from your Picasa online album, as well as calendars, stationery and other templates from the PIXMA Cloud. Google Cloud Print and Apple AirPrint are also supported.
Superior quality fast printing
With the 5 single ink system you only need to change the colour that runs out - making printing more efficient. Canon's FINE technology with up to 9600dpi print resolution delivers ultra-sharp text and images with great levels of detail. Enjoy A4 document print speeds of 15 ipm mono or 10 ipm colour and a 10x15cm borderless photo in approx. 21 seconds.
Save money on ink and paper
Print more for less. Optional XL and XXL inks deliver significantly more pages (up to 1000 with the XXL black ink) and last longer between ink replacements - ideal if you print frequently - offering up to 30% savings per page compared to their standard equivalents. Auto 2-sided printing reduces paper usage and creates professional double-sided documents.
User-friendly operation
A 6.2cm colour display makes it easy to view selected functions and preview scanned documents and images. The Dual Function Panel features LED-lit, dual-purpose keys, which change appearance with selected mode, reducing the number of physical keys required.
Premium all-in-one
Stylish and productive this premium office all-in-one offers exceptional quality print, copy, scan and fax functions and is ideal for sharing between multiple PCs using either a wireless or Ethernet connection. Double front cassettes with 250-sheet capacity plus a fully-integrated 35-sheet 2-sided automatic document feeder ensures maximum productivity. -
Download PIXMA printing solutions app and enjoy printing from, and scanning to, your smart devices over the Wi-Fi network. Directly from the printer screen you can browse and print photos from your Picasa online album, as well as calendars, stationery and other templates from the PIXMA cloud. -
With the 5 single ink system you only need to change the color that runs out - making printing more efficient. Canon's FINE technology with up to 9600 dpi print resolution delivers ultra-sharp text and images with great levels of detail. -
Print more for less. Auto 2-sided printing reduces paper usage and creates professional double-sided documents. -
A 6.2 cm color display makes it easy to view selected functions and preview scanned documents and images.
- Canon PIXMA MX725 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
- Monthly Duty Cycle (max)
- 12000 pages
- Max Copying Speed
- 8.4 ppm (colour)
- Max Printing Speed
- Up to 15 ipm (mono) / up to 10 ipm (colour)
- Max Printing Resolution
- 9600 x 2400 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 2400 x 4800 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper
- Standard Media Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Dual Function Panel
- Power
- AC 120/230 V (50/60Hz)
- 49.1 cm x 39.6 cm x 23.1 cm
- 11.7 kg
- 2 Years
- Fax Type
- Plain paper
- Ink-jet - colour
- 12000 pages
- Interface
- AirPrint Enabled
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- 8.4 ppm (colour)
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- BorderFree, fit to page
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, pigment black
- 5-ink
- Minimum Ink Droplet Size
- 1 pl
- Ink Type
- Canon ChromaLife100+
Scanning
- Scan Element
- CIS
- Optical Resolution
- 2400 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- 250 sheets
- ADF - 35 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 20 sheets - 130 x 180 mm - 300 g/m²
- Speed Details
- Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Copying: up to 8.4 ipm - colour , Printing: 21 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows Vista SP2, Apple Mac OS X 10.6.8 or later, Windows 8, Windows RT, Android, iOS, Windows 8.1
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden
- Voltage Required
- 17 Watt
- Power Consumption Standby
- 1 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 12 sec
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
- 49.1 cm
- 39.6 cm
- 23.1 cm
- 11.7 kg
- Sound Emission
- 44 dBA (operating)
- 15 °C
- 30 °C
- 5 - 95% (non-condensing)
Service and Support
- 2 Years
