This high-performance 5-ink All-in-One has Wi-Fi and touch screen making it easy for you to print your documents and photos direct from smart devices as well as access cloud storage services.
Print, copy and scan with just a few swipes of the large touch screen using this high-performance home All-In-One
Experience a touch of class. Print, copy, scan and access the cloud with simple and smartphone-like control using this high-performance home All-In-One. A large 7.5 cm colour touch screen makes it quick and easy to navigate menus, select functions, preview images and use cloud services. -
Print superb photos direct from memory cards and cameras with Canon's FINE technology, 4,800dpi print resolution and 5 single inks
Easily print superb photos, packed with deeper blacks, more vivid reds and high levels of detail, directly from memory cards and compatible wireless cameras - thanks to 5 single inks, Canon's FINE technology and up to 4,800dpi print resolution. ISO ESAT speeds of 15.0 ipm mono and 9.7 ipm color deliver a 10x15 cm borderless photo in around 41 seconds. -
Quickly and effortlessly print and scan from smart devices with the Canon PRINT app and Wi-Fi Direct
Simply download the Canon PRINT app and you can effortlessly print and scan using your smartphone or tablet, and directly access cloud services. There's no need for a wireless router, internet connection or password with Wi-Fi Direct mode, which creates an ad hoc wireless network -
Experience the creative freedom of cloud printing and scanning with enhanced PIXMA Cloud Link
With enhanced PIXMA Cloud Link you can print photos in seconds from Instagram Facebook and Flickr and print documents from popular cloud services, such as GoogleDrive, OneDrive and Access to SlideShare . Easily upload scanned documents and photos to GoogleDrive, OneDrive and OneNote. -
Only change the color that runs out with individual ink tanks; save using optional XL inks and auto 2-sided printing
Enjoy minimum waste and maximum savings. You only need to change the color that runs out thanks to individual ink tanks. Plus you can print more pages for your money using optional XL inks and save on paper with auto 2-sided printing.
- Canon PIXMA MG6850 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
- Max Copying Speed
- 7.7 ppm (colour)
- Max Printing Speed
- Up to 15 ipm (mono) / up to 9.7 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, PIXMA Cloud Link, scan to Cloud, access point mode, print from cloud
- Power
- AC 120/230 V (50/60Hz)
- 45.5 cm x 36.9 cm x 14.8 cm
- 6.4 kg
- Enclosure Colour
- Black
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Enclosure Colour
- Black
- Supported Flash Memory
- SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card
Copying
- Max Copying Speed
- 7.7 ppm (colour)
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, fit to page, Frame Erase Copy, photo mode, Borderless copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, pigment black
- 5-ink
- Minimum Ink Droplet Size
- 2 pl
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- 100 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m²
- Speed Details
- Printing: up to 15 ipm - B/W , Printing: up to 9.7 ipm - colour , Printing: 41 sec (10 x 15 cm (4"x6")) - photo , Scanning: 19 sec (A4) - colour , Copying: up to 7.7 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Android, iOS, Windows 8.1, Apple Mac OS X 10.7.5 - 10.10, Windows 10
- Software Included
- Drivers & Utilities, Canon Full HD Movie Print, Canon My Image Garden, Canon Print Service Plug-in for Android, Quick Menu, MP Driver including Scanning Utility
- Voltage Required
- 12 Watt
- Power Consumption Standby
- 1.5 Watt
- Power Consumption Sleep
- 0.2 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 18 sec
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
- ISO/IEC 24734
- 45.5 cm
- 36.9 cm
- 14.8 cm
- 6.4 kg
- Sound Emission
- 42.5 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
