Canon PIXMA MG2550S Colour Inkjet Multifunction Printer
Quicklinx: CDLKWS00 Mfr#: 0727C008
Type: Printer / copier / scanner
Functionality: Copier, Scanner, Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
14 left in stock
£24.99 ex VAT
£29.98 inc VAT
Express delivery Delivered on Tuesday
The perfect everyday All-In-One for printing, scanning and copying. From text-heavy documents to family photos, the compact Canon PIXMA MG2550S’s print engine is built for quality and ease-of-use.
Print, scan, copy – home printing made easy:
The ideal home All-In-One, letting you print, scan and copy documents and photos at speed without compromising on quality. Simple to use, the Canon PIXMA MG2550S is a stylish, compact and desk-friendly device with powerful features for every home user.
Affordable device, premium print quality:
The Canon PIXMA MG2550S offers incredible value for money: an affordable home printer that produces superior quality documents and photos. FINE Cartridge technology means deep blacks, vivid colours and a stunning level of detail.
Up to 30% lower cost per page:
Using the optional high-capacity Canon XL ink cartridges, you can save as much as 30% on the cost per page compared to their standard equivalents. Get more pages per cartridge and go longer between cartridge replacements; the Canon PIXMA MG2550S won’t cost the earth to run.
Be creative:
Easily organise and print your photos with the face-recognition features of My Image Garden app, while CREATIVE PARK PREMIUM opens a world of creative possibilities with its selection of designs from professional artists, all available for you to use as postcards, calendars, birthday cards and much more.
Energy saving built-in:
Use less energy with Auto Power On/Off. Hit print on your laptop and watch as the printer immediately emerges from its power-saving mode, ready to print without even switching it on.
This model has replaced the PIXMA MG2450
  • Print, scan, copy - home printing made easy
    The ideal home all-in-one, letting you print, scan and copy documents and photos at speed without compromising on quality. Simple to use, the Canon PIXMA MG2550S is a stylish, compact and desk-friendly device with powerful features for every home user.
  • Affordable device, premium print quality
  • Energy saving built-in
    Use less energy with auto power on/off. Hit print on your laptop and watch as the printer immediately emerges from its power-saving mode, ready to print without even switching it on.
Canon PIXMA MG2550S - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Copying Speed
1.6 ppm (colour)
Max Printing Speed
Up to 8 ipm (mono) / up to 4 ipm (colour)
Max Printing Resolution
4800 x 600 dpi (colour)
Scanning
600 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy photo paper
Standard Media Capacity
60 sheets
Connection Availability
USB 2.0
AC 120/230 V (50/60Hz)
42.6 cm x 30.6 cm x 14.5 cm
3.5 kg
Printing Technology
Ink-jet - colour
USB 2.0
Copying
Max Copying Speed
1.6 ppm (colour)
Maximum Copies
21
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
60 sheets
Input tray - 60 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
Speed Details
Printing: up to 8 ipm (A4) - B/W , Printing: up to 4 ipm (A4) - colour , Scanning: 14 sec (A4) , Copying: up to 1.6 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows 8.1, Windows 10, Apple Mac OS X 10.7.5 - 10.11
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
9 Watt
Power Consumption Standby
1 Watt
First Copy Out Time Colour
31 sec
42.6 cm
30.6 cm
14.5 cm
3.5 kg
5 °C
35 °C
10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CDLK 044331
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £21.77
Ref: CDLK 044241
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £16.93
Ref: CDLK 044254
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £17.17
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Functionality: Scanner
Functionality: Printer
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 34ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Stock Status: While stocks last
Stock Status: Used Stock
Stock Status: Clearance
