Canon PIXMA iP2850 Printer with USB Connectivity
Quicklinx: 9LQTWS00 Mfr#: 8745B008AA
Easy, affordable, everyday printing.
This compact printer delivers affordable, high quality printing thanks to Canon's FINE technology and optional XL ink cartridges. With USB connectivity it's a perfect personal desktop printer.
  • Affordable home printer
    An easy-to-use and affordable home printer with two ink cartridges ideal for printing everyday documents and occasional photos. Simple USB connectivity and compact design make it ideally suited for a personal desk printer.
  • Quality prints
    Print high-quality documents and images with impressive levels of detail, thanks to Canon's FINE technology and hybrid ink system. The color cartridge uses dye-based inks for vivid color printing, while the black cartridge contains pigment ink for crisp, sharp text.
  • Save money on ink
    Print more for less. XL cartridges deliver significantly more pages and last longer between ink replacements - ideal if you print frequently - and can deliver up to 30% savings per page compared to their standard equivalents.
  • My Image Garden
    My image Garden makes it easy to organize and print your photos. Advanced features like face recognition let you search through all the images on your PC, even those long forgotten, and use them to create attractive new designs for printing.
  • Smart Web printing
    The auto clip function of the Easy-WebPrint EX plug-in for Internet Explorer makes it simple to print only what you need from the web. Clip selected information from multiple web pages and print on a single page to save paper.
  • Save energy
    Auto power off automatically switches the printer off if not used for a set time - saving you energy. Auto power on conveniently turns the printer back on when you start printing. Quiet mode can significantly reduce operating noise for near silent printing at home.
Canon PIXMA iP2850 - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
2.3 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 8 ipm - B/W , Up to 4 ipm - colour
Max Resolution (Colour)
4800 x 600 dpi
USB 2.0
Media Type
Envelopes, plain paper, photo paper, glossy photo paper, glossy paper
Total Media Capacity
60 sheets
Media Handling
60-sheet input tray
AC 120/230 V
Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1, Windows RT
42.6 cm x 23.5 cm x 13.4 cm
2 Years
Printer Type
Printer
Inkjet Technology
Minimum Ink Droplet Size
2 pl
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Print Speed
Wired
USB 2.0
4800 x 600 dpi
Media Handling
60-sheet input tray
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Media Weight
64 g/m² - 275 g/m²
60 sheets
Media Feeders
1 x automatic - 60 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 275 g/m²
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ink cartridge (pigmented black) , 1 x ink cartridge (colour)
Power supply
AC 120/230 V
Frequency Required
50/60 Hz
8 Watt
Power Consumption Stand by
0.8 Watt
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden
15 °C
30 °C
10 - 80% (non-condensing)
42.6 cm
23.5 cm
13.4 cm
2.3 kg
Service and Support
2 Years
