Connect and print on the move with the ultimate portable printer. This lightweight printer can fit into a laptop bag and lets you print direct from smart devices and the cloud - with outstanding results.
Ultimate portable printing
Connect and print on the go. Wherever life takes you this lightweight, slimline printer is the ultimate companion for portable and stylish printing from smartphones, tablets and the cloud thanks to advanced Wi-Fi connectivity. -
Cloud connected
Go direct to the cloud. Enjoy the freedom to print effortlessly from the internet, wherever you are, using just your smartphone or tablet. With improved PIXMA Cloud Link you can print office documents, PDFs and JPGs direct from cloud services such as Dropbox, Google Drive, OneDrive and Evernote. Plus you can print photos in seconds from Facebook, Twitter and online albums and - all without using a PC. -
Smartphone and tablet ready
You're smartphone ready and so is this printer. Simply download Canon's PIXMA Printing Solutions app for your smartphone or tablet. By using the app you can directly access cloud services. You can even check printer status, the manual or real-time ink levels over Wi-Fi or internet. To complete your mobile connectivity options, Apple AirPrint and Google Cloud Print support is also available. -
Exceptional quality
Impress on the go with exceptional quality printing. Print professional looking documents with sharp text and photos with rich color contrast and - thanks to Canon's FINE technology with enhanced 5-ink system and up high print resolution. Printing is fast too. Enjoy high print speeds that can deliver a beautiful 10 x 15 cm borderless photo in your hand in few seconds. -
Cost effective, convenient printing
For maximum convenience you can adjust printer settings to extend the amount of printing by using 'Save Black Ink Mode'. Don't worry if you run out of black ink when you're out and about, the printer will keep on going by creating composite black from the other colored inks. -
Wire-free printing
Experience the ultimate in portability and go mobile with the optional rechargeable battery pack. Ideal for when you want to print where there's no mains power supply.
- Canon PIXMA iP110 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 2 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 5-ink - cyan, magenta, yellow, black, pigment black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 9 ipm - B/W , Up to 5.8 ipm - colour , Up to 0.88 min/page - photo - 100 x 150 mm
- Max Resolution (Colour)
- 9600 x 2400 dpi
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Media Type
- Envelopes, plain paper, photo stickers, glossy photo paper, matt photo paper
- Total Media Capacity
- 50 sheets
- Networking
- Print server
- Printer Features
- Borderless printing
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Windows 8.1, Windows RT
- Microsoft Certification
- Compatible with Windows 7
- 32.2 cm x 18.5 cm x 6.2 cm
- Printer Type
Printer
- Inkjet Technology
- Minimum Ink Droplet Size
- 1 pl
- Ink Cartridge Configuration
- 1 pigment black ink tank, 1 colour ink tank (cyan, magenta, yellow, black)
- Ink Type
- Canon ChromaLife100
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- 9600 x 2400 dpi
- Direct Printing Specifications
- PictBridge
- Printer Features
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Media Weight
- 64 g/m² - 275 g/m²
- 50 sheets
- Media Feeders
- 1 x automatic - 50 sheets weight: 64 g/m² - 275 g/m²
- Networking
- Print server
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (yellow/cyan/magenta/black)
- PIXMA Cloud Link
- Frequency Required
- 50/60 Hz
- 10 Watt
- Power Consumption Stand by
- 1.8 Watt
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - HD 3 GB , MacOS X - HD 1.5 GB
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
- Sound Emission (Operating)
- 38.5 dBA
- 32.2 cm
- 18.5 cm
- 6.2 cm
- 2 kg
