Canon PIXMA iP110 Portable Printer
Quicklinx: DBW3WS00 Mfr#: 9596B008
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Stock Status: Used Stock
£165.74 ex VAT
£198.88 inc VAT
Connect and print on the move with the ultimate portable printer. This lightweight printer can fit into a laptop bag and lets you print direct from smart devices and the cloud - with outstanding results.
  • Ultimate portable printing
    Connect and print on the go. Wherever life takes you this lightweight, slimline printer is the ultimate companion for portable and stylish printing from smartphones, tablets and the cloud thanks to advanced Wi-Fi connectivity.
  • Cloud connected
    Go direct to the cloud. Enjoy the freedom to print effortlessly from the internet, wherever you are, using just your smartphone or tablet. With improved PIXMA Cloud Link you can print office documents, PDFs and JPGs direct from cloud services such as Dropbox, Google Drive, OneDrive and Evernote. Plus you can print photos in seconds from Facebook, Twitter and online albums and - all without using a PC.
  • Smartphone and tablet ready
    You're smartphone ready and so is this printer. Simply download Canon's PIXMA Printing Solutions app for your smartphone or tablet. By using the app you can directly access cloud services. You can even check printer status, the manual or real-time ink levels over Wi-Fi or internet. To complete your mobile connectivity options, Apple AirPrint and Google Cloud Print support is also available.
  • Exceptional quality
    Impress on the go with exceptional quality printing. Print professional looking documents with sharp text and photos with rich color contrast and - thanks to Canon's FINE technology with enhanced 5-ink system and up high print resolution. Printing is fast too. Enjoy high print speeds that can deliver a beautiful 10 x 15 cm borderless photo in your hand in few seconds.
  • Cost effective, convenient printing
    For maximum convenience you can adjust printer settings to extend the amount of printing by using 'Save Black Ink Mode'. Don't worry if you run out of black ink when you're out and about, the printer will keep on going by creating composite black from the other colored inks.
  • Wire-free printing
    Experience the ultimate in portability and go mobile with the optional rechargeable battery pack. Ideal for when you want to print where there's no mains power supply.
Canon PIXMA iP110 - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
2 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
5-ink - cyan, magenta, yellow, black, pigment black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 9 ipm - B/W , Up to 5.8 ipm - colour , Up to 0.88 min/page - photo - 100 x 150 mm
Max Resolution (Colour)
9600 x 2400 dpi
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Media Type
Envelopes, plain paper, photo stickers, glossy photo paper, matt photo paper
Total Media Capacity
50 sheets
Print server
Printer Features
Borderless printing
AC 120/230 V
Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Windows 8.1, Windows RT
Microsoft Certification
Compatible with Windows 7
32.2 cm x 18.5 cm x 6.2 cm
Printer Type
Printer
Inkjet Technology
Minimum Ink Droplet Size
1 pl
Ink Cartridge Configuration
1 pigment black ink tank, 1 colour ink tank (cyan, magenta, yellow, black)
Ink Type
Canon ChromaLife100
Print Speed
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
9600 x 2400 dpi
Direct Printing Specifications
PictBridge
Printer Features
Borderless printing
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Media Weight
64 g/m² - 275 g/m²
50 sheets
Media Feeders
1 x automatic - 50 sheets weight: 64 g/m² - 275 g/m²
Print server
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (colour (cyan, magenta, yellow, black))
PIXMA Cloud Link
AC 120/230 V
Frequency Required
50/60 Hz
10 Watt
Power Consumption Stand by
1.8 Watt
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden
System Requirements Details
Windows XP/Vista/7/8 - HD 3 GB , MacOS X - HD 1.5 GB
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Operating)
38.5 dBA
32.2 cm
18.5 cm
6.2 cm
2 kg
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DBW3 041971
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £125.80
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Printer
Wireless Capability: Wireless
Brand: Canon
Price Range Ex VAT: 150 - 300
