Canon Pixma IP110 Colour Inkjet Wireless Printer
Quicklinx: B06ZWS00 Mfr#: 9596B028
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
39 in stock
£182.23 ex VAT
£218.67 inc VAT
Connect and print on the move with the ultimate portable printer. This lightweight printer can fit into a laptop bag and lets you print direct from smart devices and the cloud - with outstanding results.
  • Ultimate portable printing
    Connect and print on the go. Wherever life takes you this lightweight, slimline printer is the ultimate companion for portable and stylish printing from smartphones, tablets and the cloud thanks to advanced Wi-Fi connectivity.
  • Cloud connected
    Go direct to the cloud. Enjoy the freedom to print effortlessly from the internet, wherever you are, using just your smartphone or tablet. With improved PIXMA Cloud Link you can print office documents, PDFs and JPGs direct from cloud services such as Dropbox, Google Drive, OneDrive and Evernote. Plus you can print photos in seconds from Facebook, Twitter and online albums and - all without using a PC.
  • Smartphone and tablet ready
    You're smartphone ready and so is this printer. Simply download Canon's PIXMA Printing Solutions app for your smartphone or tablet. By using the app you can directly access cloud services. You can even check printer status, the manual or real-time ink levels over Wi-Fi or internet. To complete your mobile connectivity options, Apple AirPrint and Google Cloud Print support is also available.
  • Exceptional quality
    Impress on the go with exceptional quality printing. Print professional looking documents with sharp text and photos with rich color contrast and - thanks to Canon's FINE technology with enhanced 5-ink system and up high print resolution. Printing is fast too. Enjoy high print speeds that can deliver a beautiful 10 x 15 cm borderless photo in your hand in few seconds.
  • Cost effective, convenient printing
    For maximum convenience you can adjust printer settings to extend the amount of printing by using 'Save Black Ink Mode'. Don't worry if you run out of black ink when you're out and about, the printer will keep on going by creating composite black from the other colored inks.
  • Wire-free printing
    Experience the ultimate in portability and go mobile with the optional rechargeable battery pack. Ideal for when you want to print where there's no mains power supply.
Canon PIXMA iP110 - printer - colour - ink-jet - with LK-62 battery
Printer Type
Photo printer - ink-jet - colour
2 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
5-ink - cyan, magenta, yellow, black, pigment black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 9 ipm - B/W , Up to 5.8 ipm - colour , Up to 0.88 min/page - photo - 100 x 150 mm
Max Resolution (Colour)
9600 x 2400 dpi
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Media Type
Envelopes, plain paper, photo stickers, glossy photo paper, matt photo paper
Total Media Capacity
50 sheets
Printer Features
Borderless printing
AC 120/230 V
Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Windows 8.1, Windows RT
Microsoft Certification
Compatible with Windows 7
32.2 cm x 18.5 cm x 6.2 cm
Bundled with
LK-62 battery
Printer Type
Bundled with
LK-62 battery
Printer
Inkjet Technology
Minimum Ink Droplet Size
1 pl
Ink Cartridge Configuration
1 pigment black ink tank, 1 colour ink tank (cyan, magenta, yellow, black)
Ink Type
Canon ChromaLife100
Print Speed
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
9600 x 2400 dpi
Direct Printing Specifications
PictBridge
Printer Features
Borderless printing
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Media Weight
64 g/m² - 275 g/m²
50 sheets
Media Feeders
1 x automatic - 50 sheets weight: 64 g/m² - 275 g/m²
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (colour (cyan, magenta, yellow, black))
PIXMA Cloud Link
AC 120/230 V
Frequency Required
50/60 Hz
10 Watt
Power Consumption Stand by
1.8 Watt
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden
System Requirements Details
Windows XP/Vista/7/8 - HD 3 GB , MacOS X - HD 1.5 GB
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Operating)
38.5 dBA
32.2 cm
18.5 cm
6.2 cm
2 kg
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 150 - 300
