Canon PIXMA G2501 Colour Inkjet Multifunction Printer
Quicklinx: FRZXWS00 Mfr#: 0617C042
An efficient multi-functional printer, with high yield ink bottles, allowing you to create low cost stunning prints for both documents and photos, at home or in the office.
Canon PIXMA G2501 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Refillable Tank
Max Copying Speed
1.7 ppm (colour)
Max Printing Speed
Up to 8.8 ipm (mono) / up to 5 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
600 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB 2.0
Office Machine Features
Refillable ink tank
AC 120/230 V (50/60Hz)
44.5 cm x 33 cm x 16.3 cm
5.8 kg
Printing Technology
Ink-jet - colour
USB 2.0
Refillable ink tank
Copying
Max Copying Speed
1.7 ppm (colour)
Maximum Copies
21
Copying Features
Fit to page, Borderless copy
Printing
Inkjet Technology
Refillable Tank
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
Speed Details
Printing: up to 8.8 ipm - B/W , Printing: up to 5 ipm - colour , Printing: 60 sec (10 x 15 cm (4"x6")) - photo , Scanning: 19 sec (A4) - colour , Copying: up to 1.7 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows 8.1, Windows 10, Apple Mac OS X 10.7.5 - 10.11
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
11 Watt
Power Consumption Standby
0.8 Watt
First Copy Out Time Colour
32 sec
Consumables Included
2 x ink bottle (pigmented black) , 1 x ink bottle (cyan) , 1 x ink bottle (magenta) , 1 x ink bottle (yellow)
44.5 cm
33 cm
16.3 cm
5.8 kg
Sound Emission
46 dBA (operating)
5 °C
35 °C
10 - 90% (non-condensing)
