Canon Pimxa MX495 Colour Inkjet Multifunction Printer
Quicklinx: B8F1WS00 Mfr#: 0013C008
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
Sorry but this product has been discontinued.
View used stock
Connect to the cloud with this affordable Wi-Fi All-In-One. Ideal for the home you can print, copy, scan and fax with ease as well as share functions between multiple devices including smartphones and tablets.
  • Share versatile functionality at home
    Enjoy cost effective, everyday functionality at home with PIXMA MX495, which allows easy wireless sharing of print, copy, scan and fax functions between multiple devices and features a stylish, ultra-small, space saving footprint that fits easily into any environment.
  • Fast high quality printing
    Experience fast high quality printing at 8.8 ipm (mono) and 4.4 ipm (color), with up to 4800 dpi resolution and great levels of detail.
  • Seamless connection with smart devices
    Print from and scan seamlessly to smartphones and tablets with full Apple iOS and Android device support, which includes Apple AirPrint for easy wireless printing from an iPhone, iPad or iPod Touch without an additional app.
  • Mobile printing
    Print directly from mobile devices without joining a secure Wi-Fi network thanks to Access Point Mode or print from virtually anywhere with Google Cloud Print support.
  • Quick multipage scan, copy and fax with 20 sheet ADF
    Be more productive thanks to a fully-integrated 20-sheet Automatic Document Feeder that makes scanning, copying or faxing of large documents quick and easy.
Canon PIXMA MX495 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max)
1000 pages
Max Copying Speed
3.6 ppm (colour)
Max Printing Speed
Up to 8.8 ipm (mono) / up to 4.4 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, glossy photo paper, matte photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link
AC 120/230 V (50/60Hz)
43.5 cm x 18.9 cm x 29.5 cm
5.9 kg
Enclosure Colour
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1000 pages
USB 2.0, Wi-Fi(n)
AirPrint Enabled
PIXMA Cloud Link
Enclosure Colour
Copying
Max Copying Speed
3.6 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Minimum Ink Droplet Size
2 pl
Scanning
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 50 pages
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
ADF - 20 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 8.8 ipm - B/W , Printing: up to 4.4 ipm - colour , Copying: up to 3.6 ipm - colour , Printing: 70 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows Vista SP2, Windows 8, Windows RT, Android, iOS, Windows 8.1, Apple Mac OS X 10.7.5 or later
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden
7 Watt
Power Consumption Standby
1.6 Watt
First Copy Out Time Colour
28 sec
Consumables Included
1 x Cartridge (pigmented black) , 1 x Cartridge (colour)
43.5 cm
18.9 cm
29.5 cm
5.9 kg
Sound Emission
44.5 dBA (operating)
15 °C
30 °C
10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: B8F1 040697
Condition: - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £14.65
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Stock Status: Clearance
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
