It is designed for cost-effective black and white printing in connected multi-user businesses.
Make black and white printing easy and convenient with this Wi-Fi-enabled, cloud-ready 4-in-1 printer. Fast, energy-efficient operation and 33 ppm printing saves you time and money.
- Canon i-SENSYS MF6180dw - multifunction printer (B/W)
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 impressions
- Max Copying Speed
- Up to 33 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 33 ppm
- Max Printing Resolution
- Up to 1200 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, heavy-weight paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 39 cm x 47.3 cm x 43.1 cm
- 19.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 50000 impressions
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 33 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Up to 33 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, UFRII LT
- Image Enhancement Technology
- Automatic Image Refinement
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Max Battery Backup Time
- 1 hour(s)
- Total Memory Capacity
- Up to 512 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 19 station(s)
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 210 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, Double Sided Faxing, fax activity reports
Document & Media Handling
- Min Original Size
- 128 x 139.7 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: B5 (176 x 250 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 128 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Copying: up to 33 ppm (A4) - B/W , Printing: up to 33 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, IPsec, 802.1x
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
- Voltage Required
- 1200 Watt
- Power Consumption Standby
- 9 Watt
- Power Consumption Sleep
- 2.2 Watt
- Warm-Up Time
- 11 sec
- First Copy Out Time B/W
- 8 sec
- Consumables Included
- 1 x Cartridge (black) - Canon 719
- ENERGY STAR Certified
- 39 cm
- 47.3 cm
- 43.1 cm
- 19.1 kg
- Sound Emission
- 53 dBA (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
