For efficient small office printing, without compromising on performance, quality or reliability MAXIFY MB5455 is your ideal choice. With high quality, marker resistant inks, Wi-Fi and Ethernet connectivity and single pass two-sided scanning, you can print at high volumes, faster than ever before.
Rapid Print & Scan:
Quick First Print enables very fast First Print Out Time (FPOT), approx 6 seconds mono. You can also quickly scan both sides of a document using single pass 2 sided automatic document feeder (ADF).
High quality prints, every time:
Dual Resistant High Density ink has been especially developed for business printing. This high quality ink gives you vivid colours, deep blacks and crisp text, without the worry of smudging.
Easy to use, easy to be productive:
A large 8.8cm colour touchscreen provides easy access to all of MAXIFY MB5455 functions. In addition to a high-capacity 500 sheet feeder, 50 sheet automatic document feeder and double-sided printing, MAXIFY MB5455 also supports a variety of paper sizes and types - from A4 plain paper, to labels, envelopes, photo paper and even two-sided ID card copying - taking the stress out of common office print jobs.
Low running costs:
With MAXIFY MB5455, you can achieve superior printing quality, that doesn't cost the earth to run. With low power consumption combined with ink yields providing 2,500 mono pages and 1,500 colour pages, there are now longer stretches between having to replace cartridges.
Simple to manage and maintain:
Simple Network Management Protocol (SNMP) allows you to integrate your printer into your work place, making it easy to run as part of a busy office environment. MAXIFY MB5455 does this by giving you the ability to track records of use, ink levels, error status and page counts of all the printers in your network. In addition to this you can also filter by IP addresses to restrict printing access and provide secure scan-to-email.
This model has replaced the MAXIFY MB5350
A large color touchscreen provides easy access to all of MAXIFY MB5450 series functions. In addition to a high-capacity sheet feeder and double-sided printing, the MAXIFY MB5450 series also supports a variety of paper sizes and paper types, taking the stress out of common office print jobs. -
Low running costs
With MAXIFY MB5450 series, you can achieve superior printing quality, that doesn't cost the earth to run. With efficient power consumption, the stretches between having to replace cartridges are longer.
- Canon MAXIFY MB5455 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 11.5 ppm (colour)
- Max Printing Speed
- Up to 24 ipm (mono) / up to 15.5 ipm (colour)
- Max Printing Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3.5"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
- Standard Media Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 46.3 cm x 39.4 cm x 35.1 cm
- 12.9 kg
- 2-year warranty (France - 3 years with product registration)
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 1500 pages
- Display Diagonal Size
- 3.5"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Dual Resistant High Density (DRHD)
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 500 sheets
- 2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 24 ipm (A4) - B/W , Printing: up to 15.5 ipm (A4) - colour , Copying: up to 22 ipm - B/W , Copying: up to 11.5 ipm - colour , Scanning: up to 23 ipm - B/W duplex , Scanning: up to 23 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, MS Windows 7 SP1, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 or later
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX
- Voltage Required
- 27 Watt
- Power Consumption Standby
- 0.9 Watt
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
- Limited warranty - 2 years
- Regional Warranty Exceptions
- France - 3 years with product registration
- 46.3 cm
- 39.4 cm
- 35.1 cm
- 12.9 kg
- Sound Emission
- 56 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
Canon PGI-2500 XL Black Ink Tank | In Stock | £22.82 |
Canon PGI-2500 XL Cyan Ink Tank | In Stock | £17.97 |
Canon PGI-2500 XL Magenta Ink Tank | In Stock | £17.97 |
Canon PGI-2500 XL Yellow Ink Tank | In Stock | £17.97 |
