Canon MAXIFY MB5455 A4 InkJet Multifunction Printer
Quicklinx: CFKBWS00 Mfr#: 0971C028
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 24ppm
£167.42 ex VAT
£200.90 inc VAT
For efficient small office printing, without compromising on performance, quality or reliability MAXIFY MB5455 is your ideal choice. With high quality, marker resistant inks, Wi-Fi and Ethernet connectivity and single pass two-sided scanning, you can print at high volumes, faster than ever before.
Rapid Print & Scan:
Quick First Print enables very fast First Print Out Time (FPOT), approx 6 seconds mono. You can also quickly scan both sides of a document using single pass 2 sided automatic document feeder (ADF).
High quality prints, every time:
Dual Resistant High Density ink has been especially developed for business printing. This high quality ink gives you vivid colours, deep blacks and crisp text, without the worry of smudging.
Easy to use, easy to be productive:
A large 8.8cm colour touchscreen provides easy access to all of MAXIFY MB5455 functions. In addition to a high-capacity 500 sheet feeder, 50 sheet automatic document feeder and double-sided printing, MAXIFY MB5455 also supports a variety of paper sizes and types - from A4 plain paper, to labels, envelopes, photo paper and even two-sided ID card copying - taking the stress out of common office print jobs.
Low running costs:
With MAXIFY MB5455, you can achieve superior printing quality, that doesn't cost the earth to run. With low power consumption combined with ink yields providing 2,500 mono pages and 1,500 colour pages, there are now longer stretches between having to replace cartridges.
Simple to manage and maintain:
Simple Network Management Protocol (SNMP) allows you to integrate your printer into your work place, making it easy to run as part of a busy office environment. MAXIFY MB5455 does this by giving you the ability to track records of use, ink levels, error status and page counts of all the printers in your network. In addition to this you can also filter by IP addresses to restrict printing access and provide secure scan-to-email.
This model has replaced the MAXIFY MB5350
  • Easy to use, easy to be productive
    A large color touchscreen provides easy access to all of MAXIFY MB5450 series functions. In addition to a high-capacity sheet feeder and double-sided printing, the MAXIFY MB5450 series also supports a variety of paper sizes and paper types, taking the stress out of common office print jobs.
  • Low running costs
    With MAXIFY MB5450 series, you can achieve superior printing quality, that doesn't cost the earth to run. With efficient power consumption, the stretches between having to replace cartridges are longer.
Canon MAXIFY MB5455 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 11.5 ppm (colour)
Max Printing Speed
Up to 24 ipm (mono) / up to 15.5 ipm (colour)
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
Standard Media Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, access point mode
AC 120/230 V (50/60Hz)
46.3 cm x 39.4 cm x 35.1 cm
12.9 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 1500 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Dual Resistant High Density (DRHD)
Automatic Duplexing
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
500 sheets
2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 24 ipm (A4) - B/W , Printing: up to 15.5 ipm (A4) - colour , Copying: up to 22 ipm - B/W , Copying: up to 11.5 ipm - colour , Scanning: up to 23 ipm - B/W duplex , Scanning: up to 23 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, MS Windows 7 SP1, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 or later
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX
27 Watt
Power Consumption Standby
0.9 Watt
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
46.3 cm
39.4 cm
35.1 cm
12.9 kg
Sound Emission
56 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Ink-jet
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 150 - 300
