MAXIFY MB5350 is a powerful All-in-One for the most demanding small office environments. It features fast 2-sided printing and scanning, 500-sheet paper capacity, usage controls plus smartphone and cloud connectivity.
Powerful all-in-one for small offices
Be productive and stay connected with this robust high-speed all-in-one designed for demanding small office environments. With Wi-Fi and Ethernet connectivity plus professional print quality - and usage controls for added peace of mind - this is the perfect office companion. -
High-speed document printing
Never wait around for your business documents again. Fast A4 document ISO print speeds are combined with a similarly rapid Quick First Print time. -
Business quality
Dual Resistant High Density inks produce sharp text and vivid colors. These pigment inks have outstanding fastness - so they won't fade over time - and are marker and friction resistant too making them perfect for high quality business documents. -
Added productivity when needed
Make light work of every task including multi-page scanning and copying thanks to two 250-sheet paper cassettes, an integrated single pass 2-sided 50-sheet ADF and a large color touch screen. Effortless, double-sided printing is also available for added professionalism and lower paper consumption. -
With MAXIFY Cloud Link you can print from popular cloud services like Evernote, Dropbox, OneDrive or Google Drive directly from the printer screen or from a smartphone using the MAXIFY Printing Solutions app. Scan to email, Apple AirPrint and Google Cloud Print functions are also supported.
- Canon MAXIFY MB5350 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 10 ppm (colour)
- Max Printing Speed
- Up to 23 ipm (mono) / up to 15 ipm (colour)
- Max Printing Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper
- Standard Media Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- MAXIFY Cloud Link
- Power
- AC 120/230 V (50/60Hz)
- 46.3 cm x 39.4 cm x 35.1 cm
- 13.1 kg
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 1500 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- MAXIFY Cloud Link
- Localisation
- United Kingdom
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Dual Resistant High Density (DRHD)
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 9 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- 500 sheets
- 2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 23 ipm (A4) - B/W , Printing: up to 15 ipm (A4) - colour , Copying: up to 21 ipm - B/W , Copying: up to 10 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows Server 2003, MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX
- Voltage Required
- 31 Watt
- Power Consumption Standby
- 1 Watt
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
- 46.3 cm
- 39.4 cm
- 35.1 cm
- 13.1 kg
- Sound Emission
- 54 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
