All-In-One colour inkjet for home offices. The Canon MAXIFY MB2755 provides mobile printing and cloud integration, while its 500-sheet paper capacity and fast 24 images per minute (ipm) mono print speed maximise productivity.
For home offices that demand productivity:
A fully featured printer, scanner, copier and fax designed for home offices. With a large 500-sheet paper cassette and 50-sheet automatic document feeder, the Canon MAXIFY MB2755 produces outstanding prints with deep, dense blacks, vivid colours and crisp text using its marker- and friction-resistant DRHD inks. This quality doesn't come at the expense of speed: print A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in colour, while first page out time (FPOT) is just 6 seconds.
Keep running costs to a minimum:
From low energy consumption of just 0.2 kWh (TEC) to the individually replaceable colour cartridges, economy is a priority. Black cartridges provide an ISO yield of 1,200 pages and colour cartridges 900 pages. The optional 4-colour multipack contains a full set of replacement inks for even better value.
Designed for productivity:
Double-sided printing and support for a variety of paper sizes and types, from A4 plain paper to labels, envelopes, photo paper and even two-sided ID card copying makes light work of common office print jobs. Printing, copying, scanning or faxing is just a few taps away, with a highly responsive 7.5 cm (3") TFT colour touchscreen and improved interface.
Mobile-ready, cloud-ready, work-ready:
Support for Google Cloud Print, Apple AirPrint (iOS), Mopria and the Canon PRINT app provide quick and simple printing and scanning from mobile devices. You can print from the cloud and scan and save documents to cloud services. Supported services include Google Drive, Dropbox, Evernote, OneNote, OneDrive and Concur. Built in Access Point mode means that smart device users can connect to the printer without a Wi-Fi network.
Comprehensive monitoring and maintenance capability:
IP address filtering enables restricted access options, giving permission to only a select number of users, while SMTP email support allows secure scan-to-email. A range of further options allow system administrators to quickly and easily configure the printer and restrict certain operations, such as scan-to-USB.
Network integration:
IT managers and system administrators will appreciate the Canon MAXIFY MB2755s' Simple Network Management Protocol (SNMP) compatibility, making device management and integration into existing office networks easy. SNMP enables a range of maintenance monitoring functions, including ink levels, error status, and page counts.
This model has replaced the MAXIFY MB2350
- Canon MAXIFY MB2755 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 200 - 1000 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 11.5 ppm (colour)
- Max Printing Speed
- Up to 24 ipm (mono) / up to 15.5 ipm (colour)
- Max Printing Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
- Standard Media Capacity
- 500 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, Mobile Printing, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 46.3 cm x 38.9 cm x 32 cm
- 12.1 kg
- 2-year warranty (France - 3 years with product registration)
- Fax Type
- Plain paper
- Ink-jet - colour
- 15000 pages
- 200 - 1000 pages
- Display Diagonal Size
- 3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Dual Resistant High Density (DRHD)
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 500 sheets
- 2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 24 ipm (A4) - B/W , Printing: up to 15.5 ipm (A4) - colour , Copying: up to 22 ipm - B/W , Copying: up to 11.5 ipm - colour , Scanning: up to 18.5 ipm - B/W , Scanning: up to 15.5 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, MS Windows 7 SP1, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 or later
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX
- Voltage Required
- 26 Watt
- Power Consumption Standby
- 0.9 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
- Limited warranty - 2 years
- Regional Warranty Exceptions
- France - 3 years with product registration
- 46.3 cm
- 38.9 cm
- 32 cm
- 12.1 kg
- Sound Emission
- 56 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
Canon MB2050/MB2350 Black Ink | In Stock | £18.98 |
Canon MB2050/MB2350 Cyan Ink | In Stock | £12.44 |
Canon MB2050/MB2350 Magenta Ink | In Stock | £12.44 |
Canon MB2050/MB2350 Yellow Ink | In Stock | £12.44 |
Canon PGI-1500 BK/C/M/Y Multipack | In Stock | £30.90 |
