Outstanding multifunction color inkjet printer, scanner, copier and fax, with print and scan support for mobile devices and cloud services, 19 ipm mono print speed and a range of network features.
High capacity, high quality
Versatile printer, scanner, copier and fax designed for home offices that need great mono and color print quality with a low cost per page. With a large feeder and automatic document feeder, the Canon MAXIFY MB2150 Series produces outstanding prints with vivid colors and crisp text using its marker- and friction-resistant DRHD inks. The Canon MAXIFY MB2150 Series prints A4 at a fast 19 ipm mono and 13 ipm color, while its first page out time (FPOT) is just 6 seconds. -
Productive and easy to use
Double-sided printing and support for a variety of paper sizes and types - from A4 plain paper to labels, envelopes, photo paper and even two-sided ID card copying - makes light work of common office print jobs. Built for productivity, the printer is quick and simple to use: whether printing, copying, scanning or faxing, they're all within easy each with the Canon MAXIFY MB2150 Series' TFT color screen. -
Monitoring and maintenance capabilities
IP address filtering provides access rights to only a select number of users, while SMTP support allows secure scan-to-email within an office network. System administrators can quickly and easily configure the printer and restrict certain operations, such as scan-to-USB. -
Simple network integration
System administrators will appreciate the Canon MAXIFY MB2150 Series' Simple Network Management Protocol (SNMP) compatibility, a device management standard that makes it easy to integrate the printer into existing office networks. SNMP enables a range of maintenance monitoring functions, including ink levels, error status, and page counts.
- Canon MAXIFY MB2150 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 200 - 1000 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 10 ppm (colour)
- Max Printing Speed
- Up to 19 ipm (mono) / up to 13 ipm (colour)
- Max Printing Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.5"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
- Standard Media Capacity
- 250 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, Mobile Printing, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 46.3 cm x 38.9 cm x 26 cm
- 10.6 kg
- 2-year warranty (France - 3 years with product registration)
- Fax Type
- Plain paper
- Ink-jet - colour
- 15000 pages
- 200 - 1000 pages
- Display Diagonal Size
- 2.5"
- Interface
- AirPrint Enabled
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Dual Resistant High Density (DRHD)
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- Paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 19 ipm (A4) - B/W , Printing: up to 13 ipm (A4) - colour , Copying: up to 18 ipm - B/W , Copying: up to 10 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, MS Windows 7 SP1, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 or later
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX
- Voltage Required
- 27 Watt
- Power Consumption Standby
- 0.9 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
- Limited warranty - 2 years
- Regional Warranty Exceptions
- France - 3 years with product registration
- 46.3 cm
- 38.9 cm
- 26 cm
- 10.6 kg
- Sound Emission
- 56 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
Canon MB2050/MB2350 Black Ink | In Stock | £19.01 |
Canon MB2050/MB2350 Cyan Ink | In Stock | £12.47 |
Canon MB2050/MB2350 Magenta Ink | In Stock | £12.47 |
Canon MB2050/MB2350 Yellow Ink | In Stock | £12.47 |
Canon PGI-1500 BK/C/M/Y Multipack | In Stock | £30.90 |
