Built for productivity, performance, and reliability. Fast 24 ipm mono and 15.5 ipm color printing with a yield of up to 2,500 pages, low running costs, plus Wi-Fi - perfect for small offices.
A heavy-duty printer for hardworking offices:
Colour inkjet printer with the speed, capacity and economy to be an essential part of any small office. With a high-capacity 500-sheet paper cassette, the Canon MAXIFY iB4150 produces outstanding prints with vivid colours and crisp text using its marker- and friction-resistant DRHD inks. The Canon MAXIFY iB4150 prints A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in colour, while its first page out time (FPOT) is just 6 seconds.
Outstanding economy:
From low power consumption to high yield ink cartridges and individually replaceable colour cartridges, the Canon MAXIFY iB4150 is designed to reduce running costs. Black cartridges provide an ISO yield of 2,500 pages and colour cartridges 1,500 pages, leaving your office to get on with its work without constantly changing cartridges. Furthermore, a 4-colour multipack option is available for even more cost-effective printing.
Versatile office printing:
The Canon MAXIFY iB4150 makes it simple to be productive and get jobs done. Double-sided printing and support for a variety of paper sizes and types, from A4 plain paper, to labels, envelopes, photo paper, make light work of common office print jobs. Packed with easy-to-use features, the Canon MAXIFY iB4150 is built to give you all the printing options you need for typical office use.
In the cloud or on mobile:
Support for Google Cloud Print, Apple AirPrint (iOS), Mopria and the Canon PRINT app provide quick and simple printing from mobile devices. You can even print from popular cloud services, including Google Drive, Dropbox, Evernote, OneNote and OneDrive. Built-in Access Point mode means that smart device users can connect to the printer without a Wi-Fi network.
Management and monitoring made easy:
The Canon MAXIFY iB4150 delivers incredible print quality and greater productivity for small office environments, but it also provides advanced administrator features to make it simple to manage, maintain and control. A range of further options allow system administrators to quickly and easily configure the printer and restrict operations.
SNMP network integration:
The Canon MAXIFY iB4150 Simple Network Management Protocol (SNMP) compatibility means it's easy to integrate the printer into an existing office network. SNMP enables a range of maintenance and monitoring functions, including ink levels, error status, and page counts.
This model has replaced the MAXIFY IB4050
Color inkjet printer with the speed, capacity and economy to be an essential part of any small office. With a high-capacity 500-sheet paper cassette, the Canon MAXIFY iB4150 produces outstanding prints with vivid colors and crisp text using its marker- and friction-resistant DRHD inks. The Canon MAXIFY iB4150 prints A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in color, while its first page out time (FPOT) is just 6 seconds. -
Outstanding economy
From low power consumption to high yield ink cartridges and individually replaceable color cartridges, the Canon MAXIFY iB4150 is designed to reduce running costs. Black cartridges provide an ISO yield of 2,500 pages and color cartridges 1,500 pages, leaving your office to get on with its work without constantly changing cartridges. Furthermore, a 4-color multipack option is available for even more cost-effective printing. -
The Canon MAXIFY iB4150 makes it simple to be productive and get jobs done. Double-sided printing and support for a variety of paper sizes and types, from A4 plain paper, to labels, envelopes, photo paper, make light work of common office print jobs. Packed with easy-to-use features, the Canon MAXIFY iB4150 is built to give you all the printing options you need for typical office use. -
The Canon MAXIFY iB4150 delivers incredible print quality and greater productivity for small office environments, but it also provides advanced administrator features to make it simple to manage, maintain and control. A range of further options allow system administrators to quickly and easily configure the printer and restrict operations. -
- Canon MAXIFY iB4150 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 9.6 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 89 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 24 ipm - B/W - A4 (210 x 297 mm) , Up to 15.5 ipm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 1200 dpi
- Max Resolution (Colour)
- 600 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Media Type
- Envelopes, plain paper, high resolution paper, luster photo paper, glossy paper, matte paper, semi-gloss paper
- Total Media Capacity
- 500 sheets
- Media Handling
- 2x 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Networking
- Print server
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Vista SP2, Microsoft Windows Server 2008, Android, Microsoft Windows 7 SP1, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows RT, Apple MacOS X 10.8.5 or later, Windows 10, Windows 10 Mobile
- 46.3 cm x 39.4 cm x 29 cm
- Printer Type
Printer
- Inkjet Technology
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Type
- Dual Resistant High Density (DRHD)
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 1200 dpi
- 600 x 1200 dpi
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 89 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 64 g/m² - 275 g/m²
- 500 sheets
- Media Feeders
- 2 x automatic - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
Duty Cycle
- 30000 pages
- 250 - 1500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
- MAXIFY Cloud Link, Access Point Mode
- Power Device
- Power supply
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 27 Watt
- Power Consumption Stand by
- 0.9 Watt
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX
- OS Required
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
- Sound Emission (Operating)
- 53 dBA
- 46.3 cm
- 39.4 cm
- 29 cm
- 9.6 kg
