Canon MAXIFY iB4150 Colour Inkjet Printer
Cashback available - see in product for more info
Cashback
Quicklinx: CDLMWS00 Mfr#: 0972C008
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
12 in stock
£114.55 ex VAT
£137.46 inc VAT
Built for productivity, performance, and reliability. Fast 24 ipm mono and 15.5 ipm color printing with a yield of up to 2,500 pages, low running costs, plus Wi-Fi - perfect for small offices.
A heavy-duty printer for hardworking offices:
Colour inkjet printer with the speed, capacity and economy to be an essential part of any small office. With a high-capacity 500-sheet paper cassette, the Canon MAXIFY iB4150 produces outstanding prints with vivid colours and crisp text using its marker- and friction-resistant DRHD inks. The Canon MAXIFY iB4150 prints A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in colour, while its first page out time (FPOT) is just 6 seconds.
Outstanding economy:
From low power consumption to high yield ink cartridges and individually replaceable colour cartridges, the Canon MAXIFY iB4150 is designed to reduce running costs. Black cartridges provide an ISO yield of 2,500 pages and colour cartridges 1,500 pages, leaving your office to get on with its work without constantly changing cartridges. Furthermore, a 4-colour multipack option is available for even more cost-effective printing.
Versatile office printing:
The Canon MAXIFY iB4150 makes it simple to be productive and get jobs done. Double-sided printing and support for a variety of paper sizes and types, from A4 plain paper, to labels, envelopes, photo paper, make light work of common office print jobs. Packed with easy-to-use features, the Canon MAXIFY iB4150 is built to give you all the printing options you need for typical office use.
In the cloud or on mobile:
Support for Google Cloud Print, Apple AirPrint (iOS), Mopria and the Canon PRINT app provide quick and simple printing from mobile devices. You can even print from popular cloud services, including Google Drive, Dropbox, Evernote, OneNote and OneDrive. Built-in Access Point mode means that smart device users can connect to the printer without a Wi-Fi network.
Management and monitoring made easy:
The Canon MAXIFY iB4150 delivers incredible print quality and greater productivity for small office environments, but it also provides advanced administrator features to make it simple to manage, maintain and control. A range of further options allow system administrators to quickly and easily configure the printer and restrict operations.
SNMP network integration:
The Canon MAXIFY iB4150 Simple Network Management Protocol (SNMP) compatibility means it's easy to integrate the printer into an existing office network. SNMP enables a range of maintenance and monitoring functions, including ink levels, error status, and page counts.
This model has replaced the MAXIFY IB4050
  • A heavy-duty printer for hardworking offices
    Color inkjet printer with the speed, capacity and economy to be an essential part of any small office. With a high-capacity 500-sheet paper cassette, the Canon MAXIFY iB4150 produces outstanding prints with vivid colors and crisp text using its marker- and friction-resistant DRHD inks. The Canon MAXIFY iB4150 prints A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in color, while its first page out time (FPOT) is just 6 seconds.
  • Outstanding economy
    From low power consumption to high yield ink cartridges and individually replaceable color cartridges, the Canon MAXIFY iB4150 is designed to reduce running costs. Black cartridges provide an ISO yield of 2,500 pages and color cartridges 1,500 pages, leaving your office to get on with its work without constantly changing cartridges. Furthermore, a 4-color multipack option is available for even more cost-effective printing.
  • Versatile office printing
  • Management and monitoring made easy
  • SNMP network integration
Canon MAXIFY iB4150 - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
9.6 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
89 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 24 ipm - B/W - A4 (210 x 297 mm) , Up to 15.5 ipm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
600 x 1200 dpi
Max Resolution (Colour)
600 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Media Type
Envelopes, plain paper, high resolution paper, luster photo paper, glossy paper, matte paper, semi-gloss paper
Total Media Capacity
500 sheets
Media Handling
2x 250-sheet paper cassette
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Print server
AC 120/230 V
Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Vista SP2, Microsoft Windows Server 2008, Android, Microsoft Windows 7 SP1, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows RT, Apple MacOS X 10.8.5 or later, Windows 10, Windows 10 Mobile
46.3 cm x 39.4 cm x 29 cm
Printer Type
Printer
Inkjet Technology
Ink Cartridge Configuration
4 individual ink tanks
Ink Type
Dual Resistant High Density (DRHD)
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
600 x 1200 dpi
600 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
89 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
64 g/m² - 275 g/m²
500 sheets
Media Feeders
2 x automatic - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
Duty Cycle
30000 pages
250 - 1500 pages
Print server
Remote Management Protocol
SNMP
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
MAXIFY Cloud Link, Access Point Mode
Power supply
AC 120/230 V
Frequency Required
50/60 Hz
27 Watt
Power Consumption Stand by
0.9 Watt
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Operating)
53 dBA
46.3 cm
39.4 cm
29 cm
9.6 kg
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: 24ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 100 - 150
