Canon LiDE 110
Quicklinx: 74HQWS00 Mfr#: 4507B010AA
Are you looking for a dedicated scanning solution with great quality, versatility and a compact design? Then the CanoScan LiDE110 color image scanner is sure to impress. The CanoScan LiDE110 features the quality, speed and ease of use you need with a maximum resolution of 2400 x 4800 (optical) dpi for excellent scanning quality for both photos and documents.
You'll immediately notice how easy the CanoScan LiDE110 is to use. Auto document fix automatically delivers beautiful, easy-to-view scans by advanced image analysis and area-by-area data correction while the auto scan mode feature automatically detects the original and saves its appropriate settings. Need to share information? The CanoScan LiDE110 has four EZ buttons that enable you to scan, copy, email or create a PDF faster than ever.
You'll also be able to proudly join the generation green initiative as its one USB cable for data and power provides lower power consumption.
  • EZ buttons
    Have the flexibility with your originals as you utilize the four EZ buttons to automate the entire scanning process. Copy, scan and create email attachments or PDF files simply with the push of a button.
  • Scan mode
    At last, you have the ability to bring eight steps into one as you scan a photo, document, business card, textbook or personal notebook and have it automatically recognized. In addition, the original is automatically cropped to proper size, scanned and saved in the appropriate file format. All of this is achieved with the press of a single button.
  • Auto document fix
    Auto document fix delivers beautiful, easy-to-view scans by advanced image analysis and area-by-area data correction, automatically. So, your document text can be darkened with pronounced edges for clear, sharp text that's easy to read, and pictures will maintain color tone and contrast
  • Advanced Z-Lid
    The Z-Lid extends up and over the platen to scan large items such as notebooks, textbooks and other thick documents.
  • One plug scanning
    Consolidate the number of wires in your work area as one simple cable provides a Hi-Speed USB connection and power.
  • Hi-Speed USB
    Scan and transfer images to your computer with the fastest possible scanning speeds with this connection. The Hi-Speed USB interface also allows for quick previews of your images to your computer.
Canon CanoScan LiDE 110 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Interpolated Resolution
19200 dpi x 19200 dpi
Scan Speed
16 sec / page
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6, Microsoft Windows Vista SP2, Apple MacOS X 10.5, Microsoft Windows Vista SP1, Apple MacOS X 10.4.11, Microsoft Windows XP SP3
Microsoft Certification
Compatible with Windows 7
25 cm x 37 cm x 4 cm
1.6 kg
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Bulb / Light Source Type
RGB LED array
Scan Speed
16 sec / page
Control Panel Buttons Functions
Copy, email, AutoScan, Scan-to-PDF
Scanner Speed Details
16 sec/scan - colour - A4 - 300 dpi , 3.7 ms/line - colour - 300 dpi , 16.7 ms/line - colour - 2400 dpi , 3.7 ms/line - greyscale - 300 dpi , 5.6 ms/line - greyscale - 2400 dpi , 3.7 ms/line - black & white - 300 dpi , 5.6 ms/line - black & white - 2400 dpi
Scanner Features
Powered by USB port
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper
Manual
Interfaces Details
USB 2.0
Power Consumption Operational (Standby)
2.5 Watt (1.4 Watt)
Software Included
ScanGear, Canon Solution Menu, MP Navigator EX
Additional Requirements
CD-ROM, XGA monitor
System Requirements Details
Windows 7 - 1 GHz - RAM 1 GB , Windows 7 64-bit Edition - 1 GHz - RAM 2 GB , Windows Vista - 1 GHz - RAM 512 MB , Windows XP - 300 MHz - RAM 128 MB , MacOS X 10.4.11 - PowerPC G3 RAM 256 MB , MacOS X 10.5 - PowerPC G4 RAM 512 MB , MacOS X 10.6 - Intel x86 RAM 1 GB
25 cm
37 cm
4 cm
1.6 kg
5 °C
35 °C
10 - 90%
