Canon LEGRIA HF G25
Canon LEGRIA HF G25
Quicklinx: 8GVPWS00 Mfr#: 8063B004AA
  • SDHC Memory Card
Wide angle HD lens, exceptional audio and full manual controls unleash your creativity. Designed to match the creative passion of video enthusiasts, the LEGRIA HF G25 features a wide angle lens, extensive manual controls and exceptional audio for stunning HD movies.
  • 30.4 mm wide angle lens
    Canon's high performance HD video lens technology delivers a superb 30.4 mm, F1.8 lens with a smooth, 10x optical zoom, and 8-Blade iris for natural looking de-focus effects.
  • Advanced HD CMOS pro sensor
    The advanced HD CMOS pro sensor gives you superb low light performance and a wide dynamic range. The sensor originally designed and manufactured by Canon for its professional camcorders has further improved light transmittance providing an extra 20%. Boost in low-light sensitivity.
  • Full manual control
    A manual lens ring allows intuitive control of focus. Full manual control of exposure, aperture, shutter speed and gain is possible via the touch screen LCD. A custom key and manual dial put you in complete control of your creativity.
  • Optical intelligent image stabilization
    Intelligent is the perfect solution to combat camera shake. It automatically detects the scene and selects exactly the right optical image stabilizer settings from 4 modes to counteract movement and prevent blur. It ensures sharp, detailed videos in every situation leaving you free to concentrate on shooting.
  • Audio scene select
    It's simple to make your movies sound as good as they look with audio scene select and a high-sensitivity, built-in zoom microphone. Just select from 5 scene modes and audio settings are optimized automatically to match the scene you're shooting.
  • Instant AF, face detection
    Instant AF provides fast and accurate focusing for pin-sharp HD quality. Face detection automatically optimizes camcorder settings for perfectly focused and exposed people shots.
  • Protective lens hood with barrier
    A large lens hood that shuts out unwanted flare from external light sources is included as standard. It incorporates a fast-opening lens barrier that automatically protects without the need for a separate lens cap. So you will always be ready to shoot.
Canon LEGRIA HF G25 - camcorder - storage: flash card
Camcorder - 1080p
Media Type
Flash card
Memory Card Slot
Dual SD card
Image Processor
DIGIC DV III
Internal Storage
32 GB flash
Sensor Resolution
2.37 MP
Effective Sensor Resolution
Video: 2.07 MP - Photo: 2.07 MP
Lens System
Zoom lens - 10x zoom - 4.25 - 42.5 mm - f/1.8-2.8
Focus Adjustment
Automatic, manual
Min Focus Distance
2 cm
Digital Zoom
200x
Image Stabiliser
Optical
Viewfinder
Electronic - 0.24" - colour - LCD
Display
LCD display - 3.5"
Supported Battery
Canon BP-808 Li-ion rechargeable battery - 890 mAh (included)
Composite video/audio, HDMI, USB 2.0
9.5 cm x 21 cm x 8.2 cm
565 g
Camcorder - 1080p
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
2.37 MP
Sensor Qty
1 CMOS
Effective Video Resolution
2.07 MP
Effective Photo Resolution
2.07 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
HD CMOS Pro
Optical Sensor Size
1/3"
Optical Zoom
10x
Digital Zoom
200x
Video Recording Modes
SP, LP, FXP, MXP, XP+
Image Processor
DIGIC DV III
Faders
Wipe fader, auto fade
Image Stabiliser
Optical
Built-in Optical Image Stabiliser
Face Detection
Surround Sound
5.1 channel surround sound ready, Dolby Digital AC-3 (2 channel) recording
Zebra pattern
Print Standard
PictBridge support
Auto Focus
TTL contrast detection
Image Recording Format
JPEG
Exposure & White Balance
Min Illumination
0.1 lux
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Spotlight, portrait mode, night mode, fireworks, low light, sports mode, sunset, beach, snow
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, shade, fluorescent light (daylight)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/2 sec
Lens System
Focal Length Equivalent to 35mm Camera
30.4 - 304mm
Focus Adjustment
Automatic, manual
Min Focus Distance
2 cm
Zoom Adjustment
Motorised drive
Filter Size
58 mm
Built-in lens shield, aspherical lens
Additional Features
Self-Timer Delay
10 sec, 2sec
Low Lux / Night Mode
Additional Features
Built-in speaker, sharpness control, accessories hot shoe, saturation control, brightness control, takes photos while film recording, Pre-Rec function, relay recording, Video Snapshot mode, HD-to-SD downconversion, face detection, 25p Cinema Mode, auto backlight compensation, Story Creator, Touch Decoration, Bayer mosaic RGB filter
Viewfinder
Viewfinder Type
Electronic - LCD
Viewfinder Colour Support
Viewfinder Diagonal Size
0.24"
Viewfinder Resolution
260,000 pixels
Optical Viewfinder Field Coverage
100%
Display
3.5" LCD display
Display Format
922,000 pixels
Display Form Factor
Rotating
Touch Screen
Display Features
Contrast control, display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Zoom, sensitivity control
Connector Type
Component video output , Composite video/audio output , HDMI output , USB 2.0 , Microphone , Headphones , Control-L (LANC)
Software
Software
Drivers & Utilities
Lens hood, power adapter, USB cable, pen stylus, HDMI cable, audio / video cable, IR remote control
Battery Type
Canon BP-808 Lithium Ion
Details
Battery Life Details
Video recording - 1.9 hours
Memory / Storage
Memory Card Slot
Dual SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Internal Storage
32 GB flash
Image Storage
JPEG 1920 x 1080
Video Capture
AVCHD - 1920 x 1080 - 24Mbps - require SDHC Class 4 or higher , AVCHD - 1920 x 1080 - 17Mbps - require SDHC Class 4 or higher , 1440 x 1080 - 12Mbps , 1440 x 1080 - 7Mbps , 1440 x 1080 - 5Mbps
9.5 cm
21 cm
8.2 cm
565 g
