Wide angle HD lens, exceptional audio and full manual controls unleash your creativity. Designed to match the creative passion of video enthusiasts, the LEGRIA HF G25 features a wide angle lens, extensive manual controls and exceptional audio for stunning HD movies.
30.4 mm wide angle lens
Canon's high performance HD video lens technology delivers a superb 30.4 mm, F1.8 lens with a smooth, 10x optical zoom, and 8-Blade iris for natural looking de-focus effects. -
Advanced HD CMOS pro sensor
The advanced HD CMOS pro sensor gives you superb low light performance and a wide dynamic range. The sensor originally designed and manufactured by Canon for its professional camcorders has further improved light transmittance providing an extra 20%. Boost in low-light sensitivity. -
Full manual control
A manual lens ring allows intuitive control of focus. Full manual control of exposure, aperture, shutter speed and gain is possible via the touch screen LCD. A custom key and manual dial put you in complete control of your creativity. -
Optical intelligent image stabilization
Intelligent is the perfect solution to combat camera shake. It automatically detects the scene and selects exactly the right optical image stabilizer settings from 4 modes to counteract movement and prevent blur. It ensures sharp, detailed videos in every situation leaving you free to concentrate on shooting. -
Audio scene select
It's simple to make your movies sound as good as they look with audio scene select and a high-sensitivity, built-in zoom microphone. Just select from 5 scene modes and audio settings are optimized automatically to match the scene you're shooting. -
Instant AF, face detection
Instant AF provides fast and accurate focusing for pin-sharp HD quality. Face detection automatically optimizes camcorder settings for perfectly focused and exposed people shots. -
Protective lens hood with barrier
A large lens hood that shuts out unwanted flare from external light sources is included as standard. It incorporates a fast-opening lens barrier that automatically protects without the need for a separate lens cap. So you will always be ready to shoot.
- Canon LEGRIA HF G25 - camcorder - storage: flash card
- Product Type
- Camcorder - 1080p
- Media Type
- Flash card
- Memory Card Slot
- Dual SD card
- Image Processor
- DIGIC DV III
- Internal Storage
- 32 GB flash
- Sensor Resolution
- 2.37 MP
- Effective Sensor Resolution
- Video: 2.07 MP - Photo: 2.07 MP
- Lens System
- Zoom lens - 10x zoom - 4.25 - 42.5 mm - f/1.8-2.8
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 2 cm
- Digital Zoom
- 200x
- Image Stabiliser
- Optical
- Viewfinder
- Electronic - 0.24" - colour - LCD
- Display
- LCD display - 3.5"
- Supported Battery
- Canon BP-808 Li-ion rechargeable battery - 890 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 9.5 cm x 21 cm x 8.2 cm
- 565 g
- Product Type
- Camcorder - 1080p
- Enclosure Colour
- Black
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 2.37 MP
- Sensor Qty
- 1 CMOS
- Effective Video Resolution
- 2.07 MP
- Effective Photo Resolution
- 2.07 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- HD CMOS Pro
- Optical Sensor Size
- 1/3"
- Optical Zoom
- 10x
- Digital Zoom
- 200x
- Video Recording Modes
- SP, LP, FXP, MXP, XP+
- Image Processor
- DIGIC DV III
- Faders
- Wipe fader, auto fade
- Image Stabiliser
- Optical
- Built-in Optical Image Stabiliser
- Face Detection
- Surround Sound
- 5.1 channel surround sound ready, Dolby Digital AC-3 (2 channel) recording
- Zebra pattern
- Print Standard
- PictBridge support
- Auto Focus
- TTL contrast detection
- Image Recording Format
- JPEG
- Interface
Exposure & White Balance
- Min Illumination
- 0.1 lux
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Spotlight, portrait mode, night mode, fireworks, low light, sports mode, sunset, beach, snow
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, shade, fluorescent light (daylight)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 1/2 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 30.4 - 304mm
- Focus Adjustment
- Automatic, manual
- 2 cm
- Zoom Adjustment
- Motorised drive
- Filter Size
- 58 mm
- Built-in lens shield, aspherical lens
Additional Features
- Self-Timer Delay
- 10 sec, 2sec
- Low Lux / Night Mode
- Additional Features
- Built-in speaker, sharpness control, accessories hot shoe, saturation control, brightness control, takes photos while film recording, Pre-Rec function, relay recording, Video Snapshot mode, HD-to-SD downconversion, face detection, 25p Cinema Mode, auto backlight compensation, Story Creator, Touch Decoration, Bayer mosaic RGB filter
Viewfinder
- Viewfinder Type
- Electronic - LCD
- Viewfinder Colour Support
- Viewfinder Diagonal Size
- 0.24"
- Viewfinder Resolution
- 260,000 pixels
- Optical Viewfinder Field Coverage
- 100%
Display
- 3.5" LCD display
- Display Format
- 922,000 pixels
- Display Form Factor
- Rotating
- Touch Screen
- Display Features
- Contrast control, display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Zoom, sensitivity control
- Connector Type
- Component video output , Composite video/audio output , HDMI output , USB 2.0 , Microphone , Headphones , Control-L (LANC)
Software
- Software
- Drivers & Utilities
- Included Accessories
- Lens hood, power adapter, USB cable, pen stylus, HDMI cable, audio / video cable, IR remote control
- Battery Type
- Canon BP-808 Lithium Ion
- Details
- Battery Life Details
- Video recording - 1.9 hours
Memory / Storage
- Memory Card Slot
- Dual SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Internal Storage
- 32 GB flash
- Memory Card Included
- No
- Image Storage
- JPEG 1920 x 1080
- Video Capture
- AVCHD - 1920 x 1080 - 24Mbps - require SDHC Class 4 or higher , AVCHD - 1920 x 1080 - 17Mbps - require SDHC Class 4 or higher , 1440 x 1080 - 12Mbps , 1440 x 1080 - 7Mbps , 1440 x 1080 - 5Mbps
- 9.5 cm
- 21 cm
- 8.2 cm
- 565 g
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
