Canon Laser Multifunction Printer i-SENSYS MF8340CDN
Quicklinx: 85M6WS00 Mfr#: 5120B018AA
High volume printing is now available to all, with the i-SENSYS MF8340Cdn. It prints and copies at 20 pages per minute in both color and mono, supported by a 50-sheet duplex automatic document feeder. There's little time lost waiting for output with a fast first copy out time. With Canon's Quick First-Print technologies, there's also minimal delay on printing and copying straight from sleep mode.
The superior energy efficiency of the i-SENSYS MF8340Cdn will reduce your costs - and your carbon footprint. ENERGY STAR compliant, its Typical Energy Consumption (TEC) is low. Thanks to Canon's On-Demand fixing technology it has low energy consumption in sleep mode, without compromising on performance.
  • Accelerate workflows
  • Easy, one touch working
    Simplicity is built-in as standard on this all-in-one device - with one touch solution keys enabling you to access key functions easily. These include quick scanning direct to your PC; eco-copying for combining several pages into a single print out, saving paper and money; and secure print for protecting confidential documents and reducing waste. There's also an easy-to-use, backlit 5-line LCD display with intuitive menus, which shows essential information on screen. This allows users to navigate between different functions quickly and get the most from the device.
  • Send and share
    Save time and be more productive by distributing your documents using Canon's send functionality. This enables you to scan and send documents direct to email, a network folder or a USB memory key. Sending and sharing documents is also made easier by using compact PDF compression technology to reduce files to around a tenth of the size achievable with standard techniques - with no impact on quality.
  • Save energy and money
Canon i-SENSYS MF8340Cdn - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 impressions
Max Copying Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
2400 x 600 dpi (colour)
Scanning
600 x 600 dpi
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
125 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, scan to folder
AC 230 V (50/60Hz)
43 cm x 48.4 cm x 47.9 cm
31 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
40000 impressions
Display
5 lines
Standard Memory
256 MB 256 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
Automatic Duplexing
First Print Out Time B/W
14.5 sec
First Print Out Time Colour
14.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
300 sheets
50 sheets
125 sheets
ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 125 sheets , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m²
Speed Details
Printing: up to 20 ppm (A4) - colour , Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour , Copying: up to 20 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.4.9 - 10.7.x
Software Included
Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
AC 230 V (50/60Hz)
1200 Watt
Power Consumption Standby
23 Watt
Power Consumption Sleep
1.8 Watt
Warm-Up Time
23 sec
First Copy Out Time B/W
15.5 sec
First Copy Out Time Colour
16.2 sec
Consumables Included
1 x toner cartridge (black) - up to 1200 pages - Canon 718 Starter , 1 x toner cartridge (cyan) - up to 1400 pages - Canon 718 Starter , 1 x toner cartridge (magenta) - up to 1400 pages - Canon 718 Starter , 1 x toner cartridge (yellow) - up to 1400 pages - Canon 718 Starter
ENERGY STAR Certified
43 cm
48.4 cm
47.9 cm
31 kg
Sound Emission
43 dB (idle) / 67 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
85M6 Canon 718 Cyan Toner In Stock £90.00
85M6 Canon LBP7200 MAGENTA TONER In Stock £95.88
85M6 Canon 718 Black Toner In Stock £87.44
85M6 Canon 718 Yellow Toner In Stock £90.00
85M6 Canon 718 Black Toner Cartridge 3.4k Yield Twin Pack In Stock £143.19
