Small and stylish enough to take everywhere, this versatile 20 Megapixel IXUS with Wi-Fi, 10x optical zoom and Intelligent Image Stabilizer lets you simply point and shoot for brilliant results every time.
Pocketable style
This ultra-slim and stylish IXUS is easy to carry with you wherever you go and features a flexible 24 mm ultra-wide 10x optical zoom lens with 20x ZoomPlus; so you can easily capture every moment, near or far, in superb quality photos and movies. Auto Zoom helps you select the best framing at the touch of a button. -
Instant HD movies
Making great movies is fun and easy. With one touch of a button you can effortlessly shoot great HD movies (720p) in MP4 format. Experience the creative versatility of shooting movies using the optical zoom and still enjoy sharp, steady results thanks to the Dynamic Image Stabilizer. -
Stunning results
Enjoy exceptional quality, detailed images ideal for creating stunning poster sized prints thanks to 20.0 Megapixels and DIGIC 4+ processing. An intelligent optical Image Stabilizer ensures sharp stills and steady movies in any situation, while the 6.8 cm (2.7") LCD screen allows easy viewing and sharing. -
Effortless creativity
Just point and shoot to capture fantastic photos or movies with one touch of the Auto Button, which allows Smart Auto to take control and choose the perfect camera settings for you. Play with your creativity in stills or movies using a range of Creative Filters such as Fish Eye, Miniature and Toy Camera.
- Canon IXUS 180 - digital camera
- Product Type
- Digital camera - 720p - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4+
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 20.0 Megapixel
- Max Video Resolution
- 1280 x 720
- Lens System
- Zoom lens - 10x zoom - 4.3 - 43 mm - f/3.0-6.9
- Focus Adjustment
- Automatic
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Intelligent IS with Enhanced Dynamic Mode)
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.7"
- Supported Battery
- Canon NB-11L Li-ion rechargeable battery - 680 mAh (included) , Canon NB-11LH Li-ion rechargeable battery - 800 mAh (optional)
- Interface
- Composite video/audio, USB 2.0
- Red
- 9.53 cm x 2.36 cm x 5.68 cm
- 138 g
- Product Type
- Enclosure Colour
- Red
- Sensor Resolution
- 20.0 Megapixel
- Optical Sensor Type
- CCD
- Total Pixels
- 20,500,000 pixels
- Effective Sensor Resolution
- 20,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 25 fps
- ISO (Max)
- 1600
- Optical Zoom
- 10x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 4+
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Face-priority AF, Subject-tracking AF, AI Focus AF
- Face Detection
- Face Detection AF/AE/FE/WB, Face Detection Self-timer
- Digital Video Format
- H.264
- Image Recording Format
- JPEG
- 1280 x 720
- Interface
- Composite video/audio, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Portrait mode, slow shutter, fireworks, low light
- Special Effects
- Fisheye, monochrome, miniature, Toy camera, Posterisation, Super Vivid
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 240mm
- Focus Adjustment
- Automatic
- Macro Focus Range
- 1cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 7 groups / 9 elements
- Built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.5 m - 4 m (wide lens) , 1 m - 2 m (tele lens)
Additional Features
- Continuous Shooting Speed
- 0.8 frames per second, 2.2 frames per second (5MP)
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, Smart Flash Exposure, Smart AUTO, primary colour filter, GPS via mobile, Auto Zoom
Display
- 2.7" LCD display
- Display Format
- 230,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 (mini-USB Type B) , Composite video/audio output
Software
- Software
- Drivers & Utilities, Canon Map Utility, Canon Image Transfer Utility, Canon CameraWindow DC
- Included Accessories
- Battery charger, wrist strap
- Battery Type
- Canon NB-11L, Canon NB-11LH Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 190 shots , Photo shooting - 245 shots (ECO mode) , Playback - 4 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 5152 x 3864 , JPEG 5152 x 2896 , JPEG 3648 x 2736 , JPEG 2048 x 1536 , JPEG 640 x 480
- Video Capture
- H.264 - 1280 x 720 - 25 fps , H.264 - 640 x 480 - 30 fps , H.264 - 1280 x 720 - 5 fps - Miniature Effect , H.264 - 1280 x 720 - 2.5 fps - Miniature Effect , H.264 - 1280 x 720 - 1.25 fps - Miniature Effect , H.264 - 640 x 480 - 6 fps - Miniature Effect , H.264 - 640 x 480 - 3 fps - Miniature Effect , H.264 - 640 x 480 - 1.5 fps - Miniature Effect
- 9.53 cm
- 2.36 cm
- 5.68 cm
- 138 g
- 0 °C
- 40 °C
- 10 - 90%
