The Canon i-SENSYS FAX-L3000IP is a heavy duty, network laser fax with advanced fax, copy and print functionality. It is able to meet the most demanding workloads. Optional SEND functionality enhances productivity and compatibility.
- Canon i-SENSYS FAX-L3000IP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 22 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 22 ppm
- Max Printing Resolution
- Up to 1200 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB 2.0, LAN
- 45.1 cm x 49.2 cm x 52 cm
- 24 kg
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- Interface
- USB 2.0, LAN
- Standard Memory
- 128 MB 128 MB
Copying
- Max Copying Speed
- Up to 22 ppm
- Max Document Enlargement
- 200%
- Max Document Reduction
- 50%
- Preset Enlargements
- 141%, 200%
- Preset Reductions
- 50%, 70%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
Printing
- Up to 22 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, UFRII LT
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Total Memory Capacity
- Up to 1500 pages
- Fax Printing Speed
- Up to 22 ppm
- Fax Printing Resolution
- 1200 x 600 dpi
- Handset
- Optional
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 80 station(s)
- Transmit verification report, automatic redialing, answering machine interface, dual-line fax capability
Document & Media Handling
- 50 sheets
- Max Media Size
- Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 128 g/m²
- Supported Media Type
- 600 sheets
- 1100 sheets
- 100 sheets
- 100 sheets
- Paper cassette - 500 sheets , ADF - 50 sheets , Bypass tray - 100 sheets
- Speed Details
- Printing: up to 22 ppm , Copying: up to 22 ppm
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows ME, MS Windows 98, MS Windows Server 2003, Apple Mac OS X 10.2.8 - 10.4.x, MS Windows Vista
- 1010 Watt
- Power Consumption Standby
- 17 Watt
- Power Consumption Sleep
- 3 Watt
- Consumables Included
- 1 x toner cartridge - up to 500 pages
- ENERGY STAR Certified
- 45.1 cm
- 49.2 cm
- 52 cm
- 24 kg
- Sound Emission
- 25 dB (idle) / 66.7 dB (operating)
