Canon ISENSYS FAX L3000IP N/W FAX
Quicklinx: 7HNDWS00 Mfr#: 1484B013AA
The Canon i-SENSYS FAX-L3000IP is a heavy duty, network laser fax with advanced fax, copy and print functionality. It is able to meet the most demanding workloads. Optional SEND functionality enhances productivity and compatibility.
Canon i-SENSYS FAX-L3000IP - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 22 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 22 ppm
Max Printing Resolution
Up to 1200 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, LAN
45.1 cm x 49.2 cm x 52 cm
24 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
USB 2.0, LAN
Standard Memory
128 MB 128 MB
Copying
Max Copying Speed
Up to 22 ppm
Up to 600 x 600 dpi
Max Document Enlargement
200%
Max Document Reduction
50%
Preset Enlargements
141%, 200%
Preset Reductions
50%, 70%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Printing
Max Printing Speed
Up to 22 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, UFRII LT
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Total Memory Capacity
Up to 1500 pages
Fax Printing Speed
Up to 22 ppm
Fax Printing Resolution
1200 x 600 dpi
Handset
Optional
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
80 station(s)
Transmit verification report, automatic redialing, answering machine interface, dual-line fax capability
Document & Media Handling
50 sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
128 g/m²
Supported Media Type
600 sheets
Max Media Capacity
1100 sheets
100 sheets
100 sheets
Paper cassette - 500 sheets , ADF - 50 sheets , Bypass tray - 100 sheets
Speed Details
Printing: up to 22 ppm , Copying: up to 22 ppm
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows ME, MS Windows 98, MS Windows Server 2003, Apple Mac OS X 10.2.8 - 10.4.x, MS Windows Vista
1010 Watt
Power Consumption Standby
17 Watt
Power Consumption Sleep
3 Watt
Consumables Included
1 x toner cartridge - up to 500 pages
ENERGY STAR Certified
45.1 cm
49.2 cm
52 cm
24 kg
Sound Emission
25 dB (idle) / 66.7 dB (operating)
