Canon imageFORMULA P-215II Document Scanner
DEDICATED ID CARD SCANNER
Quicklinx: 9KWVWS00 Mfr#: 9705B003
Type: Document scanner
Form Factor: Portable
Max Paper Size: 216 x 1000 mm
Interface: USB 2.0
Compatibility: Mac, PC
31 in stock
£214.87 ex VAT
£257.84 inc VAT
High-speed, mobile document scanner for the office, for home or on the move
The P-215II scanner was designed to improve personal productivity and efficiency anywhere, from home offices, to classrooms, even traveling in between. It can help meet the document capture needs of stationary users and "road warriors" in healthcare, legal services, financial services, and many other areas. Users can conveniently execute general purpose distributed scanning tasks and help reduce paper in the process.
Main Features
  • Speedy USB powered scanning up to 30ipm.
  • Batch scanning with 20-sheet ADF.
  • Ultra compact for space saving and mobility.
  • Supports ID and embossed card scanning.
  • Scan to Google Docs and Evernote.
  • Outstanding image quality.
  • Powerful software supports Mac and PC.
  • Enjoy Wi-Fi scanning with optional WU10.
Most productive USB-powered scanning
The imageFORMULA P-215 is the most productive scanner in its class. With double-sided scanning speeds up to 30ipm and an industry-leading 20-page automatic document feeder users can scan efficiently, in the office, at home or on the move. Full-rated scanning speeds can be powered via just a single USB cable using a USB 3.0 interface.
With a sophisticated smart silver and black design, the ultra-lightweight, compact P-215 is ideal for the office. Its small footprint allows the scanner to fit comfortably on the busy desktops. True plug-and-scan is possible by simply connecting the scanner to any PC or Mac. Canon’s unique built in CaptureOnTouch Lite software is ready to go – there’s no need to load drivers or application software.
Dedicated ID card scanner
With card scanning becoming increasingly important for ID authentication, the P-215 has its own dedicated card scanning slot. A sophisticated switchback feed mechanism ensures it quickly scans ID and embossed cards.
Enhanced image processing
Advanced technology allows for high precision scanning up to 600dpi. A rich range of image processing features, such as auto colour detection, auto text orientation recognition, ensure superb scan quality that is ideal for creating searchable PDFs.
Direct scanning to the cloud
Users have the option to scan direct to various cloud services, including Evernote, GoogleDocs™ and SharePoint. This allows information to be quickly uploaded to the cloud, for anywhere, anytime access.
Powerful software suite
The P-215 uses both ISIS and TWAIN drivers to allow for easy integration with your standard imaging application and includes a full-suite of software applications to help users work more effectively. The intuitive interface of Canon’s CaptureOnTouch software makes scanning easy. It incorporates a Full-Auto Mode function, which automatically applies the best settings to scan jobs. PageManager (Mac) and PaperPort (Windows) provides effective file management and conversion tools. While scanning business cards has never been easier with the BizCard application.
Canon imageFORMULA P-215II - document scanner - portable - USB 2.0
Document scanner - portable
Interface Type
USB 2.0
Scan Element Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 1000 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
15 ppm (mono) / 10 ppm (colour)
Max Document Size
216 mm x 1000 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Manual, automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X Lion 10.7, Windows 8, Apple MacOS X 10.5 - 10.9
Microsoft Certification
Compatible with Windows 7
28.5 cm x 9.5 cm x 4 cm
1 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 1000 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
15 ppm
Max Document Scan Speed Colour
10 ppm
Duty Cycle
500 scans per day
Scanner Speed Details
15 ppm - portrait B&W - A4 - 200 dpi , 30 ipm - duplex - portrait B&W - A4 - 300 dpi , 15 ppm - portrait greyscale - A4 - 200 dpi , 30 ipm - duplex - portrait greyscale - A4 - 300 dpi , 10 ppm - portrait colour - A4 - 200 dpi , 20 ipm - duplex - portrait colour - A4 - 200 dpi , 6 ppm - portrait colour - A4 - 300 dpi , 12 ipm - duplex - portrait colour - A4 - 300 dpi
Scanner Features
Powered by USB port, Error Diffusion, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Text Orientation Recognition, RGB Color Dropout, automatic resolution setting, Smooth Background, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Image Rotation, Shadow Cropping, Deskew, Shading Correction, Preset Gamma Curve, Contrast Arrangment, Color Drift, Edge Enhancement, USB 3.0 bus power support, Photograph Corrections, Pre-Scan, Three-Dimensional Color Correction, Trimming, Select Scanning Document Side, Scan Area Setting, Continuous Scanning
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 1000 mm
Manual, automatic
20 sheets
USB 2.0
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
7 Watt (1.5 Watt)
Software Included
Drivers & Utilities, Canon CaptureOnTouch, Nuance PaperPort, Canon CaptureOnTouch Lite, Evernote for Windows, Evernote for Mac, NewSoft Presto! BizCard, Google Docs, Presto! PageManager for Mac, SharePoint for Windows, SharePoint for Mac, EMC Captiva Cloud Runtime Controls
28.5 cm
9.5 cm
4 cm
1 kg
10 °C
32.5 °C
25 - 80%
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Canon
Price Range Ex VAT: 150 - 300
