Canon imageFORMULA P-208II Portable Document Scanner
Quicklinx: BLFQWS00 Mfr#: 9704B003
Type: Document scanner
Form Factor: Portable
Interface: USB 2.0
Compatibility: Mac, PC
More than 50 in stock
£105.89 ex VAT
£127.06 inc VAT
The Canon imageFORMULA P-208II Scan-tini personal document scanner's ultra-compact size and robust features make it ideal for mobile use at home, the office, and virtually anywhere in between. It can be moved from location to location as easily as it moves paper-based information.
The compact and stylish P-208II mobile scanner is the perfect choice for travelling executives and home users. A 10-sheet ADF and high speed duplex scanning ensure productivity is always maintained.
  • Ultra-compact, lightweight and versatile
  • Productive 16ipm double-sided scanning with 10-sheet ADF
  • Supports embossed card and photo scanning
  • Convenient, intuitive plug-and-scan operation
  • Mac and Windows compatible
  • Optional Wi-Fi Unit WU10 available
Highly productive mobile scanning
The tiny P-208II delivers impressive double-sided scanning speeds of up to 16ipm. The integrated 10-sheet ADF enables batch scanning for extra productivity: perfect for scanning contracts and associated documents. You can travel light with the P-208II as it has a footprint that's a little larger than a standard ruler and weighs only 600g. Powered directly via USB, it helps you maintain a high work rate anywhere in the home or on the road.
Plug-and-scan convenience on the go
The stylish, compact and ultra-lightweight P-208II provides true plug-and-scan convenience. With CaptureOnTouch Lite built in, and no additional software or drivers to download, you can simply connect, scan and go. Scanning functions and an improved icon-based user interface mean you will enjoy an even more intuitive scanning experience. An extended choice of plug-ins for SugarSync, OneDrive and Dropbox, alongside Google Drive™, Evernote and SharePoint, make it easy to work with your favourite software tools.
Scan various documents
The P-208II can scan a variety of media, from A4 to irregular-sized documents like embossed card, so it’s perfect for mobile users. Get organised at home and make space by scanning your household bills; or preserve your memories digitally by scanning your old photos in high quality, using a special feature that reproduces images as close to their originals as possible.
Easy-to-use image processing
The P-208II’s range of image processing features includes auto colour detection, text orientation recognition and text enhancement – to deliver high quality images and save valuable time. For convenient and intuitive scanning, use the Full Auto Mode feature that automatically applies the best settings for your document. Simply load up your documents and scan!
Flexible wireless scanning
For the freedom to scan wherever you are, combine the P-208II with the optional WU10 Wi-Fi and battery unit. Use it to wirelessly scan documents directly to your smartphone, tablet or desktop PC, or share the scanner amongst a group of users or devices via a network server or home router.
CaptureOnTouch Mobile
The powerful CaptureOnTouch mobile app gives you the flexibility to scan direct to your iPhone®, iPad® or Android device. Save valuable time with double-sided one-pass document scanning. This free app is available for both iOS and Android devices.
Canon imageFORMULA P-208II - document scanner - portable - USB 2.0
Document scanner - portable
Interface Type
USB 2.0
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
8 ppm (mono) / 8 ppm (colour)
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
10 sheets
Duty Cycle
100 scans per day
Apple MacOS, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Microsoft Certification
Compatible with Windows 7
31.25 cm x 5.65 cm x 4 cm
600 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
8 ppm
Max Document Scan Speed Colour
8 ppm
Duty Cycle
100 scans per day
Scanner Speed Details
8 ppm - black & white , 16 ipm - duplex - black & white , 8 ppm - colour , 16 ipm - duplex - colour
Scanner Features
Double feed detection, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, Text Enhancement, Text Orientation Recognition, Smooth Background, 3 Dimensional Color Correction processing, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Image Rotation, Shadow Cropping, Deskew, Shading Correction, Preset Gamma Curve, Contrast Arrangment, Edge Enhancement, Trimming, Select Scanning Document Side, Scan Area Setting, Continuous Scanning
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
10 sheets
USB 2.0
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
2.5 Watt
Power Consumption Sleep
1.5 Watt
Software Included
Drivers & Utilities, Presto! BizCard Reader, Canon CaptureOnTouch, Canon CaptureOnTouch Lite, Evernote for Windows, Evernote for Mac, Google Docs, SharePoint for Windows, SharePoint for Mac, Canon CaptureOnTouch for Mac, Presto! BizCard Reader for Mac, Google Docs for Mac, Canon CaptureOnTouch Lite for Mac
31.25 cm
5.65 cm
4 cm
600 g
10 °C
32.5 °C
25 - 80%
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Canon
Price Range Ex VAT: 100 - 150
