Brand
Canon imageFORMULA DR-M140 Document Scanner
Quicklinx: 9KX4WS00 Mfr#: 5482B003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3000 mm
Interface: USB 2.0
Compatibility: PC
Hurry, only 3 left in stock!
£576.21 ex VAT
£691.45 inc VAT
With a robust, compact design and a U-Turn paper path, the imageFORMULA DR-M140's intelligent features make it a superb productivity booster in busy office departments and workgroups.
  • Small on size, big on performance
    The DR-M140's superbly compact dimensions make it the natural choice in environments where space is often limited - from busy offices to narrow counter tops, reception desks and customer service areas. The selectable U-turn feeding mechanism ejects scanned documents via the top of the device. When not in use, the DR-M140 is small enough to store conveniently in a drawer.
  • Rapid scanning for busy workgroups and departments
    The impressive imageFORMULA DR-M140 delivers full-rated color scanning speeds of up to 40ppm/80ipm, at 300dpi, ideal for demanding paper-intensive environments where greater accuracy is needed for document data recognition and file classification.
  • The flexibility to meet all your needs
    Built on the same reliable paper transport system as its predecessor - the DR-M140 is rated to scan up to a productive 6,000 scans/day. A selectable U-turn or straight through paper path allow for smooth scanning operation of a variety of media types, including embossed cards, thick and thin media and 3m long documents.
  • Reliable paper handling
    With a robust separation mechanism the DR-M140 reliably scans mixed document sizes and weights together. Ultrasonic double feed detection quickly identifies misfeeds, while a double feed release button lets you 'ignore and continue' scanning in special cases, such as an envelope or a document with a sticky note attached.
  • High quality image processing
    The DR-M140 comes with the latest image processing features to help you achieve outstanding quality results every time. Features such as auto color detection and an auto resolution setting ensure consistently superior image results; while MultiStream accommodates workflows required for improved OCR processing.
  • Bundled software to improve productivity
    The imageFORMULA DR-M140 comes with a superb range of market-leading software. It supports scanning to multiple file formats, including PDF, PDF-A, TIFF, JPEG, BMP and PowerPoint, while users can send files direct to a network folder and SharePoint. CaptureOnTouch features an intuitive user interface, including the Full Auto-Mode feature for a simplified scanning experience. CapturePerfect offers powerful software scanning tools for more mission-critical batch scanning applications. Also included is Kofax VRS, and eCopy PDF Pro Office, providing a full and professional software suite.
Canon imageFORMULA DR-M140 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 3000 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 3000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
31.3 cm x 18.1 cm x 9.3 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 3000 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
40 ppm - portrait B&W - A4 - 300 dpi , 40 ppm - portrait colour - A4 - 300 dpi , 40 ppm - portrait greyscale - A4 - 300 dpi , 80 ipm - duplex - portrait greyscale - A4 - 300 dpi , 80 ipm - duplex - portrait B&W - A4 - 300 dpi , 80 ipm - duplex - portrait colour - A4 - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection, Bleed-through reduction, Shadow Removal, Double feed detection, Long Paper Mode, Error Diffusion, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Text Enhancement, Auto Deskew, automatic resolution setting
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3000 mm
Plain paper
Automatic
50 sheets
USB 2.0 - Mini-B
RoHS
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Power Consumption Operational (Standby)
25 Watt (1.9 Watt)
Software Included
Drivers & Utilities, Kofax VirtualReScan, Canon CaptureOnTouch, Nuance eCopy PDF Pro Office, Canon CapturePerfect 3.1
31.3 cm
18.1 cm
9.3 cm
2.6 kg
10 °C
32.5 °C
20 - 80%
Interface: USB 2.0
Compatibility: PC
Brand: Canon
Price Range Ex VAT: £500 - £750
Stock Status: In stock
