Canon imageFormula DR-M1060 Document Scanner
£75 Cashback Available
Cashback
Quicklinx: 9KX7WS00 Mfr#: 9392B003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 300 x 3000 mm
Interface: USB 2.0
Compatibility: PC
£1,428.69 ex VAT
£1,714.42 inc VAT
Ultra-compact A3 scanner offering reliable and versatile performance. A versatile and ultra-compact A3 scanner with a U-turn and selectable straight-through paper path. The DR-M1060 is perfect for reliably scanning various document types up to A3 size, while keeping footprint low.
Extremely compact
The DR-M1060 is a uniquely compact A3 scanner – ideal in corporate office departments or decentralised branch offices that have limited desktop space but require A3 scanning. Users will appreciate the comfortable and convenient operation of the front document feed and exit design.
Reliable and versatile paper handling
The U-turn and selectable straight paper path with robust feeder mechanism allows for smooth scanning of a variety of media types, including embossed cards, thick and thin media or 3m-long documents. Using Folio mode, it is also possible to scan A1 size documents. The DR-M1060 includes an array of technology for reliable paper handling. Ultrasonic double feed detection helps prevent lost images, while the Double Feed Release (DFR) feature reduces interruptions by allowing users to quickly ignore and continue scanning in special cases.
Highly productive scanning
The DR-M1060 is extremely productive with ultra-fast duplex scanning speeds of up to 120ipm (A4) and a 60-sheet document feeder. Despite its small size, it is built for handling big workloads of up to 7,500 documents a day.
Perfect image processing every time
Enjoy perfect image results with the DR-M1060’s host of advanced image processing features, such as advanced text enhancement that produces clear legible images even from feint text originals. Additional features like Auto Colour Detection, Auto Size and Deskew Correction, Text Orientation Correction and Customised Colour Dropout further enhance image quality and consistency.
Bundled software to improve productivity
Enjoy quick and effortless scanning with CaptureOnTouch software for both ad-hoc and routine tasks. For scanning larger batches of documents, CapturePerfect is ideal, with its multi-window and thumbnail views, plus flexible options like scan-to-folder, email and SharePoint. The DR-M1060 also comes with eCopy PDF Pro Office and Kofax VRS (including AIPE).
Optional extras
The DR-M1060 comes with a host of optional accessories to maintain a high level of productivity. Scan bound books, journals and fragile media with both the A4 and A3 optional Flatbed Scanner units. These USB-connected dual-scanning flatbed units work seamlessly with the DR-M1060, letting you smoothly apply the same image-enhancement features to any scan. A 2D Barcode Module is also available that enables barcode recognition of QR codes, PDF417 and Data Matrix formats through the ISIS/TWAIN drivers.
  • Extremely compact
    The DR-M1060 is a uniquely compact A3 scanner - ideal in corporate office departments or decentralized branch offices that have limited desktop space but require A3 scanning. Users will appreciate the comfortable and convenient operation of the front document feed and exit design.
  • Reliable and versatile paper handling
  • Highly productive scanning
  • Perfect image processing every time
    Enjoy perfect image results with the DR-M1060's host of advanced image processing features, such as advanced text enhancement that produces clear legible images even from feint text originals. Additional features like Auto Color Detection, Auto Size and Deskew Correction, Text Orientation Correction and Customised Color Dropout further enhance image quality and consistency.
Canon imageFORMULA DR-M1060 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
300 x 3000 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
300 mm x 3000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
60 sheets
Duty Cycle
7500 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Microsoft Certification
Compatible with Windows 7
42.6 cm x 24.6 cm x 12 cm
6.1 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
300 x 3000 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
7500 scans per day
Scanner Speed Details
60 ppm - black & white , 120 ipm - duplex - black & white , 60 ppm - colour , 120 ipm - duplex - colour
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Shadow Removal, Error Diffusion, Patch Code Detection, automatic colour detection, automatic page size detection, blank page skipping, Moire Removal, MultiStream Technology, Advanced Text Enhancement, Text Orientation Recognition, Smooth Background, 3 Dimensional Color Correction processing, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Image Rotation, Double Feed Release (DFR), Character Emphasis, Preset Gamma Curve, Edge Enhancement
TWAIN, ISIS
Media Handling
Max Document Size
300 mm x 3000 mm
Plain paper
Automatic
60 sheets
USB 2.0
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
32.5 Watt (2.5 Watt)
Software Included
Drivers & Utilities, Canon CapturePerfect, Kofax VirtualReScan, Canon CaptureOnTouch, Nuance eCopy PDF Pro Office
42.6 cm
24.6 cm
12 cm
6.1 kg
10 °C
32.5 °C
20 - 80%
Interface: USB 2.0
Compatibility: PC
Brand: Canon
Price Range Ex VAT: 1000 - 1500
