Canon imageFORMULA DR-C230 Document Scanner
Quicklinx: F3PYWS00 Mfr#: 2646C003
Type: Document scanner
Form Factor: Desktop
Interface: USB 2.0
10 in stock
£281.54 ex VAT
£337.84 inc VAT
Designed to provide excellent value and performance to both small and medium sized organizations, the imageFORMULA DR-C230 comes fully equipped with the latest technologies and features required for simple capture and advanced workflows. The device is the latest high-performance desktop workgroup scanner in Canon's award winning series of imageFORMULA document scanners.
The imageFORMULA DR-C230 is based on the successful imageFORMULA DR-C240, providing a compact, robust and reliable device with scanning speeds of 30 ppm/60 ipm. With its robust feeding mechanism the new scanner is capable of handling a variety of different media including scanning 6 mm thick passports through the 60-sheet document feeder. The compact imageFORMULA DR-C230 also includes various advanced image processing features, including text enhancement, automatic deskew and text orientation recognition, to help deliver exceptionally high quality images while saving users valuable time.
Canon imageFORMULA DR-C230 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 3000 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
60 sheets
Duty Cycle
3500 scans per day
Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.10 - 10.12
29.1 cm x 25.3 cm x 23.1 cm
2.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3500 scans per day
Scanner Speed Details
30 ppm - black & white , 30 ppm - colour
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Double feed detection, Error Diffusion, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Advanced Text Enhancement, Batch Separation, Smooth Background, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Double Feed Release (DFR), Shadow Cropping, Deskew, Color Enhancement, Contrast Arrangment, Auto Resolution, Three-Dimensional Color Correction, Scan Area Setting, Adjustable Gamma Settings, Folio Mode
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3000 mm
Automatic
60 sheets
USB 2.0 - Type B
USB cable
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
19 Watt
Power Consumption Sleep
1.4 Watt
Software Included
Drivers & Utilities
29.1 cm
25.3 cm
23.1 cm
2.8 kg
10 °C
32.5 °C
20 - 80%
Interface: USB 2.0
Brand: Canon
Price Range Ex VAT: 150 - 300
